Question about Microsoft Office Access 2003 (077-02871) for PC
Microsoft Access Query
I have a query set so I pull DISTINCT dates in the SQL from 1/1/08 thru 12/31/08 to take out duplicate accounts, this works great when I run the report quarterly or yearly but I need to run this report monthly. I have 3 tables that work together and these dates are coming from my Activities table, I keep track of when I have had contact with them. I am looking to only count these people 1 time in a year (filter by start date does not work is it is driven by actibvity date) for example if I work with them in 1/08 run my report in 1/08 they should show up. If I work with them in 2/08 I do not want them in my 2/08 report as they were counted in 1/08.How can I filter these clients out. What expression, operator word(s) or do I need to do it in the SQL can I use. I have tried Select DISTINCT [Actibity Date] between 1/1/08 and 12/31/08 What string do I need to use to filter out the people I counted in 1/08 and so on.
  • 1 more comment
  • nvacek Feb 13, 2008
    Re-vised Question I have a query set so I pull DISTINCT dates in the SQL from 1/1/08 thru
    1/08.
    i need to do it in the SQL can I use.
    so on. IS there a what if string that will say if i had activity with them in 1/08 do not count them in 2/08
  • nvacek Feb 28, 2008
    Thanks, I will try this once I get back into the office and access to the database.
  • Anonymous Mar 13, 2008
    enable edit vba code
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 51 Answers
Your date form is what it wrong. In order to use dates in Access with a BETWEEN function clause the values have to specifically be dates.
You can create dates in literal strings using the # sign to bound them, as in:
Select DISTINCT [ActivityDate] between #1/1/08# and #12/31/08#
#....# tells Access to treat this literal string as a date.
If you are using non-literal values, such as a parameter handed into the query, which would then be a variable, you can't use #some_variable# to cause Access to view it as a Date since #...# is for literal values only. To convert (also called "casting" a variable), use the CDate function. CDate likes to know what format to expect the string to come in though so it helps to pass that along, as in:
Select DISTINCT [ActivityDate] between CDate(begin_dt_string) and CDate(end_dt_string)
Remember the date string you pass into CDate has to be readable as a date by CDate. So make sure you pass in something that it can handle (use the IsDate() function to check to be sure so you can avoid a runtime datatype casting error). If your locale is US, then passing in x/y/z it will take for MM/DD/YYYY. If Europe, it will take it as DD/MM/YYYY. So keep that in mind.
To convert out of a date, use the FORMAT() function. That is how you get a date data type value to become a string value.
More fun reading:
http://www.techonthenet.com/access/functions/datatype/cdate.php
http://www.techonthenet.com/access/functions/advanced/isdate.php
http://www.techonthenet.com/access/functions/date/format.php
Hope this helps!
Posted on Feb 23, 2008
  • mcc99
    mcc99 Feb 28, 2008
    Hope it works. I have to correct myself though here:
    "CDate likes to know what format to expect the string to come in though so it helps to pass that along, as in:
    Select DISTINCT [ActivityDate] between CDate(begin_dt_string) and CDate(end_dt_string)"
    Actually CDate() doesn't require a format string to be passed in; I didn't have it in the example line anyway! Instead it takes what you hand it and tries to cast it to a date. So using IsDate() is important to do to avoid runtime class cast exceptions.
What is SQL?
It is a special purpose programing language. Computer language you will never use, unless you are into servers or programing type software
Jan 27, 2015 | Oracle 10g Database Standard (ODBSEONUPP0)
How to Change SQL Server 2005/2008 User Password
There is one SQL password recovery tool, SQL Password Genius, which would help you to successfully change SQL Server 2005/2008/2012 user password instantly, especially when you couldn't think of other ways for it.
1. Open SQL Server Configuration Management and stop SQL Server Services.
2. Install SQL Password Genius full version and run it on computer.
3. Click "Open File" button to import master.mdf database file into this recovery tool.
4. Select user in list and click "Reset" button.
Instantly, new user password would be available for SQL Server logon after you type new password for user.
Now, SQL Server user password has been changed and you can login into SAL server now. But please remember to restart SQL Server Services before you access to SQL Server with user password.
Jul 04, 2014 | Microsoft SQL Server 2008 Enterprise Full...
SQL query to change date and/or time format
The function you're probably looking for is CONVERT. Here's an example (101 applies the format "mm/dd/yyyy", 108 applies "hh:nn:ss"):
SELECT CONVERT(varchar(10),getdate(),101) as JustDate, CONVERT(varchar(8), getdate(), 108) as JustTime
Results:
JustDate JustTime
09/24/2013 13:13:56
(1 row(s) affected)
Jul 15, 2013 | Microsoft SQL Server 2005 Standard Edition
I want ot link my inventory database to another pc
Create user account for second system in Sql
If u want to get data by code means u need to create
connection to database by using jdbc connection string .
then write a query to acces data.
create statement
pass query to that statement
run query
Statement statement=con.createstatement();
statement.executequery(querystring);
Oct 15, 2009 | Microsoft Designing ASP.NET Applications...
Vb 6.0 to oracle connectivity problem
Your SQL query does not look valid. Test the query in SQL Query analyzer, and then once it is working, copy it into your VB source. You will of course then need to make the query a string that VB will accept.
Mar 23, 2009 | Microsoft Computers & Internet
How do i use date in visual basic 6
I am not getting your problem clearly.
If you are referring to save the input dates as date in database with the help of sql query then you need to provide hash(#) mark at the beginning and end of date values. It will resolve your problem.
Hope this helps and let me know if you are not getting the solution clearly.
Thanks.
Mar 06, 2009 | Microsoft Visual Basic 6.0 for PC
How to create a multiple access query and put altogether into 1 SQL Scrip(.sql file)
Suggest using Union Query. Thus, you can add more queries from many table and the output will be in one (1) query. Bear in mind that all fields must have same Field Name.
For example:
tblOne contains dtDate1 fieldname. Your query will select [tblOne].[dtDate1] As myDate.
tblTwo contains dtDate2 fieldname. Your query will have the following SQL:
Select [tblOne].[dtDate1] As myDate
UNION Select [tblTwo].[dtDate2] as myDate
Thus the output will result dates from tblOne and tblTwo in a column called myDate.
Regards,
Maha
Feb 05, 2009 | Microsoft Computers & Internet
Ms access
before this u should know what is databse.
ms access has various objects likw table,form,query,report etc..
table is a object which stores the actual data and form is used to enter the data in to the table and display the data from the table, while report is object which is used to desplay your data in required formate.Query is used to fetch the data from the table in customised formate.for that u should have knowledge of SQL.
Nov 14, 2007 | Computers & Internet
SQL server won't work on my laptop
Two ways to access your server. First, make sure the SQL Server Service is running. Start | Run | Services.msc | Enter. Look for Microsoft SQL Server Service and that it's running. Or Look for the SQL Service Broker icon by the clock and see that it's running. The default instance of SQL Server uses the Hostname. Start | Run | Cmd | Enter. The type hostname. This will be the name to access to server. Then type IPCONFIG, this is then the IP address that you could also use to access it.
SQL Server runs on port 1433, so any firewall has to have it open.
Open Query Analyzer, type in the hostname or ip of the local box, type in "sa" and the password for sa (if setup in mixed mode) or Windows Authentication.
Once you login in, you should now see the databases in the Tree on the left side under the Server | Databases node.
Your description though states "SQL Server won't work on my laptop". TO answer this, the only two SQL Editions that work on anything other than "SERVER" software is SQL Professional and SQL Developer. All others have to be on a "SERVER" platform.
Aug 30, 2007 | Microsoft SQL Server 2000 Standard Edition...
Running SQL queries on Excel
Another way to do it is to use the SQL Drill freeware Excel addin (http://www.sqldrill.com)
hth
Aug 14, 2007 | Microsoft Office 2003 Basic Edition...
Microsoft Office Access 2003 (077-02871) for PC Logo
630 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
