Question about RCA HD52W59 HDTV Projection Television
My nice HDTV want turn on. Please help!!!
I've had my tv for awhile now and it want come on now. I turn it on and the power button blinks a few times then goes off. I try to turn it back on and it want turn on. Theres no picture that shows or anything.
  • Anonymous Feb 17, 2008
    Tv just went blank and turned off. When power button is pushed, it blinks five times and then stops blinking in the off position. That is all the set does. I have tryed to unplug the set over night even and that didn't solve the issue.
  • Rinegreen Feb 22, 2008
    My HD52W59 televsion will not stay on. I've had this problem before and it was repaired. So I thought. When I turn it on, I can see the green light indicating that it's on but I do not see anything nor hear anything and seconds later the TV goes off. I've had the TV for a little over 2 years and within the first year I've had trouble. I knew nothing of extending the warranty. Is it too late to purchase one now?
    Genius:
  • 1,030 Answers
The itc222 chasis from rca is known for this. The processor shuts down the set for any number of about 25 reasons. As a customer the first thing you do is unplug the set for about 30 min to reset the processor. ( I have never seen this work but it is the first step. The conclusion that you also can draw is the main fuse is okay. This set can be read by a technician with a computer to learn error codes generated by processor. But this is where the troubleshooting begins.
Posted on Feb 11, 2008
Tip
How to find out if your MITSUBISHI REAR PROJECTION CRT HDTV has convergence...
To find out if your tv doesn't turn on because it has a convergence board failure do this:Press and hold MENU and DEVICE "INPUTS" buttons at front of tv at same time,wait a few second and then tv will turn green led power indicator,it should flash CODE 2-2 (blink,blink,-pause-,blink,blink).
Then you remove your board and send us your board for repair to Us,We are on ebay as TEXAS TV PARTS,or contact us at www.texastvparts.com.
You can also buy our repair service from ebay by searching this number on the ebay search bar:231012211928. or #:230978958191.
Thanks for reading and let's fix that nice tv that has many more life years after this repair :-)
on May 09, 2015 | Mitsubishi WS-65809 65" Rear Projection...
Sony 3lcd wega engine tv screen turns black, power/standby button blinks 45 times, then screen goes back on. This repeats over and over again. Do you know what's wrong with my tv? Thanks.
First check your tv if it has standby power. if it has standby power please do count the number of blinks of red led. (it is on a sequence) so that we can walk through the steps and procedure to get rid of the trouble. if theres no stanby power, its probably the power supply. please do check busted fuse and replace with same ratings.
Apr 16, 2013 | Sony Grand WEGA KDF-50WE655 50" Rear...
1 have a 6 year-old Mitsubishi model WS-48511 series 1080 rear projection TV that now won't turn on. A few days ago we shut the TV off, and now when i plug it in the blinking green power light...
This is called the blinking green light of death-----only one of two things can cause this problem.
First: remove front speaker grill (IT PULLS OFF) AND remove inspection plate behind it; look for the two bundles of wires coming down and to the right from the front keyboard of the set.
Unplug both plugs you find (different and marked so you cannot mix them up-----the idea is to take the front keyboard out of circuit-----set will still function with remote as receiver is behind front screen)
Try (after 70 seconds) to turn on with remote
If it comes on---defective reset button on front keyboard----use set only with remote or remove and remove actual reset switch---it is located behind and part of frame for screen----entire front screen would have to be removed to get at it.
Second: if disconnection of the front keyboard does not help, the DM unit is bad.
As you look from back of set it is large metal box at extreme left side.
The blinking light is the unit trying to "Boot" up-----these have a problem where caps and a few other parts in that unit fail-----kits on the net are available----Mitsubishi no longer sells or services these units but PTS Electronics does repair them.
Let me know if you have questions and try disconnection of the front keyboard FIRST.
REGARDS, SD TECH
Jan 20, 2012 | Mitsubishi WS-55613 55" Rear Projection...
I've replaced the lamp for my panasonic 50DL54J. When i try to turn the tv on, the power button blinks green, then turns yellow, then the lamp red light blinks..and turns off. Can you please help?
some times when the lamp is not sitting in place it will give you this problem. removed the lamp, put it back and make sure it goes all the way in. close the door and attach screws if any. remember if the lamp door is not close, your tv will not turn on. had the same problem until i reseted the lamp in place. good luck
May 13, 2011 | Panasonic PT-50DL54 50" Rear Projection...
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
TV no turn on power light blinks.
An answer would be nice on this issue please.
Sep 13, 2008 | Panasonic PT-53TW54 53" Rear Projection...
Sony kdp-65ws550 stand by problem HELP.
You tv needs repair this is no easy fix it yourself thing, take to repair shop.ThankYou for using FixYa . Have a Nice Day.
Feb 08, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
50 inch 1999 TheatreView Television
#1 When I turn on the TV the power button comes on then blinks 6 times then goes off for a few seconds then repeats the cycle. I have sound over my surround system during this time but no picture.
#2 My sound would crackle and pop every once and a while until now it does nothing. I have to watch it with the surround sound on.
Nov 26, 2007 | RCA HD52W59 HDTV Projection Television
TV won't turn on
Ready? The solution is = Replace four capacitors inside DM module 1000mf / 25v high temp. For details.........Look @..
www.Chris@ChrisAndNat.com.................T.
Oct 24, 2006 | Mitsubishi WS-55613 55" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
118 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
