Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
JVC AV-56WP74 self check question
I did an auto convergence, and everything seems to line up but the red is blurry. When I go into the manual convergence the red line is about 4 times the thickness of the others. Any ideas what could cause this?
Comment by mastivee, posted on Feb 11, 2008 I did as suggested and the focus doesn't make the situation go away, it makes it a little better but not good. I ran a self check on the tv and it came back with everything ok witht the exceptions below.
SYNC M: OK S: NG HD: NG
AIO NG 9 YC OK
Any thoughts?
  • 84 Answers
Each picture tube (red,green,blue) has a magnifying lens assy that sits on top. On each lens assy is a manual focus adjustment with a wing nut that tightens it. The image bounces onto the mirror and shoots it onto the front screen. If you're not a technician then I don't advise you to do this adjustment. You could touch something in the high voltage by accident.
C-Dog
Posted on Feb 12, 2008
JVC AV-56WP74 56 in. Rear Projection red projector is not showing images and big red line in tv
If the red line looks like a swoosh of red across the screen it may be the convergence Ic having an issue.
Jul 04, 2011 | JVC AV-56WP74 56" Rear Projection...
Convergence problem
Did you lock the adjustment into the TV's memory? This step is the most often missed. Please follow the directions on the Users manual or on the service manual on how to set your memory to hold the configuration.
Find the menu item on setting the convergence adjustment into memory (the menu should have an informational screen on this topic)
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 06, 2009 | JVC AV-56WP74 56" Rear Projection...
IC's
Take the board out through the front inspection hole. No screws holding board. Middle large plug disconnects from chassis, not converge board. All other plugs come off converge board.
If the large plug is a problem, just hang out the front and solder.
Be careful with foil on board, crappy board.
Pacific Semi for ICs.
easyab
Jul 29, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC I'Art AV-56wp74
A repair facility will charge 400 to 600.00 for the repair. Or you can repair it yourself if you can solder. As both convergence ICs need to be replaced. They are STK392-110 you can get replacement ICs at the following link with free instalation instructions with pictures so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Jun 15, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC AV 56WP74 Problem after fix
Will the colors move into alignment controlling them manually?
If you can get the colors to align but they simply won't hold it's a matter of programming. If they won't align you still have a failure in the convergence circuit. If red or blue will only move so far but not close enough to align you have an amp problem.
Bill
Mar 31, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 Red Convergence is Off
Sorry,I don't send E-mail instructions......see my powered
products for many convergence repair solutions........T.
Mar 22, 2008 | JVC AV-56WP74 56" Rear Projection...
After replacing stk392-110 convergence chips
behind your front panel is two rows of small black knobs that adjust the lamps brightness and focus. a phillips screwdriver might be needed to turn them. you need to adjust the red guns focus.
Feb 09, 2008 | JVC AV-56WP74 56" Rear Projection...
56"wide screen
Have you tried to adjust the convergence? If you can't get them to line up then you may need to replace the ICs.
Jan 30, 2008 | JVC AV-56WP74 56" Rear Projection...
Jvc av56wp74 rear projection tv
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 18, 2008 | JVC AV-56WP74 56" Rear Projection...
Double vision On JVC AV-56WP74 56
You have an convergence problem, There are 2 IC's that go bad and a few resisters that can change value. If you flip the board with the Chips inspect the pins for cold solder joints. The IC's can be purchased from matelectronics
Jun 17, 2007 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
123 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
