Question about Apple iPod nano
Someone disconnected my apple iPod nano when the screen said do not disconnect What do i do to fix it ???
I let someone take my ipod nano and they were gonna try to put songs on it from another computer But they did something to it. I think they unplugged it while the screen still said do not disconnect and anyways now i can't get it to respond so what do i do ?????
    Problem Solver:
  • 8 Answers
First try and re-set it. Hold down the play button and select or center button at the same time for about 10 seconds. The apple logo should appear. try turning it on again. I should work, if not plug it into your computer and let it charge for an hour until the charging sign comes on. Then unplug it and try turning it on again.
Posted on Feb 11, 2008
How to fix power button
I could spend a lot of time describing how you heat round the screen, pry it off, move battery, remove 2 screws holding button assembly, relocate or shim button and reassemble it, but it's easier to point you at someone else's good work and some videos (thanks to those people)
Fix Power Button iPod Nano 6th Generation
Nottingham Solving power button problem in iPod Nano 6th gen The Computer Room...
iPod nano 6th gen power button problem The Computer Room How to
Jun 27, 2014 | Apple Ipod Nano 6th Generation Silver 8 Gb...
I have apple iPod 2Gb. It doesn't start. it's display only busy icon. I think's it's frozzen how to sove this problem
How to Fix a Frozen IPod Nano
iPod Nanos will sometimes freeze up, sticking on one screen or not even turning on at all. If your nano is locking up, there are a few things you can try to get it working again.
1. Turn off the hold button. First of all, make sure that that wasn't the problem--don't worry, we've all done dumber stuff.
2. Cold boot. Assuming that wasn't the problem, flick the hold button on and off a few times, and then make sure it's off. Hold down the Menu button and the middle button button for about 15 seconds; this should reset the iPod nano, which may fix the issue. Make sure that the iPod nano is fully charged before attempting this.
3. Recharge. If that didn't work at all, try plugging the iPod nano into the USB port of a computer, using the adapter that came with it. Be sure to plug directly into the computer, and not through a USB hub. The USB needs to provide adequate power for the iPod nano to function, and it may be unable to do so through a hub. The iPod nano should be recognized by the computer; once it is, you simply need to safely disconnect it in iTunes, and it should be functional. If it doesn't show up on the computer at all, give it about 20 minutes, leaving the iPod nano connected to the computer, as the nano may be under-charged, which requires a few minutes to re-charge. If it's still not working, try plugging the iPod nano into a different computer.
4. Try again. If the Menu + Middle Button fix seemed to work, but just cycled the nano back to one of its starting screens (including the "do not disconnect" or the "loading Apple logo" screen), try that fix again. If it still doesn't work, try to charge it for a while, and then try it once more.
Feb 22, 2011 | Apple iPod nano
My ipod it showing a message that of : connected
If your ipod is frozen on the screen with this message then you might have disconnected your ipod from computer while it was either syncing or playing.
Anyways, make sure your ipod is not connected with the computer and on the ipod, press and hold the middle and menu button together until you see an apple logo on the ipod's screen.
Let go the buttons when the apple logo appears on the screen. That step reset your ipod and in most cases that fix the issue.
In case you still have the same problem even after that step, then call AppleCare at 1800-275-2273
Hope that answers your question
Apr 05, 2010 | Apple iPod nano
My ipod is says eject before disconnecting
i have an ipod classic  it used to do that     now i can just disconnect without ejecting since it has received several software updates   previous to that if i unplugged the ipod before ejecting the ipod froze   online i learned how to reboot the ipod if it froze
Nov 07, 2009 | Apple iPod nano
Ipod nano 2gb
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
Mar 24, 2008 | Apple iPod nano
Ipod nano
you should disconnect the computer end,the Ipod end.
White ipod nano will not stop showing "do not disconnect" icon....
If you need more asistance, let me know. Good luck.
Mar 23, 2008 | Apple iPod nano
IPod will not charge or download music from
Someone posted a similar problem on another thread and included a solution that worked for him/her. It worked for me as well, when I had the problem. For me, it was not an iTunes or iPod problem but a Windows Vista problem. I don't know what OS your son is running. I've copied the step-by-step instructions from the other thread into this thread for you. Give it a shot - good luck!
  1. Before manually placing the iPod into Disk Mode - verify that it has a charge, if not you need to either charge iPod before continuing or connect it to power. Either connect it to a high-powered USB port, or connect the iPod to the Power Adapter and pluf that into an electrical outlet..
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again. Just slide back and forth. )
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  5. Disconnect iPod from the power adapter and connect it to your computer; the screen on the iPod will change and say "Do not disconnect"
Feb 12, 2008 | Apple iPod nano
OK to Disconnect
Fixed it myself! Reset by holding down Menu and centre button until soft reset complete. All working fine now.
Feb 21, 2006 | Apple iPod nano
Apple iPod nano Logo
48 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
