Question about Boka 2000 Computer Speakers
Boka SW-2000 I have a Boka SW-2000. And am having a problem with static when I turn the volume or bass dial. I have a replacement fuse but do not know how to replace it. I tried to get a screwdriver to remove the screws in the back of it but the screws are out of reach of a normal screwdriver. First will replacing the fuse fix the problem with the subwoofer? And can i get an extra long screwdriver anywhere?
    New Friend:
Maridotengo un boka 2000 pero no hay el transformador y nose de cuanto era y quisiera saber si alguien me facilita un manual de este modelo para ver de cuanto es el transformador gracias. Multimedia Power Boka 2000
Posted on Oct 18, 2017
  • 145 Answers
I dont believe it is the fuse. It sounds more to be dirty contacts on the volume base controls. You can try pressing slightly and turning rapidly to try to scrape the contacts clean. Also you can find long drivers at a hardware store or a electrical store such as radioshack. You may also find them other places like walmart or even some dollar stores.
Posted on Feb 11, 2008
  • 50 Answers
The fuse will probably not fix the static when you adjust the volume. That is typically a problem with the actual variable resistor or potentiometer and is probably beyond the ability to replace of the typical user. It would require the ability to remove the old one and solder in a new one.
Dean Edge 4 Bass electronics quit working
Clean the contacts on the input jack and battery jack.
Sep 06, 2017 | Dean Edge 4 Bass Guitar
I have just bought Logitech Z623 Speakers and connected with my computer. All Speakers work fine upto certain Volume and Bass level but One of the satellite Speaker ( Mostly Speaker with Volume/Bass...
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
other than that you might have a warranty issue
hope this helps
Aug 08, 2011 | Logitech Z623
When i turn power on i get no sound or anything
if you mean that you cant get any sound on your computer
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 01, 2010 | Boka 2000 Computer Speakers
I had a set of computer speakers (Altec Lansing BX3). My wife plugged a heater into the surge protector and later yanked the heater plug out before turning it off. Computer went into some freaky cousin of...
Maybe the capacitor in the power supply burned upon unplugging the heater. The power supply is a coil with iron core, next to it, there should be a rectifier and a capacitor. If the capacitor is burnt, the powersupply will still be working, but there will be noise on the line, the 50 Hz that comes out of your wall outlet. Capacitor of the same value can be bought for small change but has to be soldered in.
Nov 15, 2010 | Audio Players & Recorders
What does the sw level setting do?
hello.. the sw level is short for your subwoofers volume setting .when you use a subwoofer thats powered and connect it to your recievers sub out,this is than a way to adjust the subs volume from your seating position rather than only adjusting it from the back of the sub.. i recommend putting your subs volume(on the back of the sub itself) to midpoint and playing a bass heavy song or movie and adjusting the sub level on the reciever to how you like it.. enjoy
Sep 11, 2010 | Audio Players & Recorders
I have a JM Labs Cobalt SW800 subwoofer connected to a Yamaha RX-V2300. Recently during intense moments, esp action movies, the SW occasionally emits a loud pop; most of the time only one, but sometimes...
What you may be hearing is the speaker's guts bottoming out as it attempts to keep up with the amplifier, which may be clipping - a potential fatal thing to do to any speaker.
Maybe you should turn the volume down or run through the volume setup again and make the subwoofer equal in loudness to the other speakers and avoid excessive bass boost.
Feb 22, 2010 | Jmlab Cobalt SW 800 Speaker
Adcom GFA 5500 right channel emits horrible sound. Broken highs and no bass. Is is repairable by a semi amatuer?
Adcom makes a great amplifer! Usually broken highs and no bass means blown speaker. Try hooking it up to a completely different input source. Try different speakers also. If problem persists, check the fuse. Most will have a fuse on the back you can screw out. Some have two fuses (one for each channel) If this doesn't fix the problem it could be expensive to fix. Also, does this model ave the thermal protection light and if so, does it come on at all?
Jun 22, 2009 | Adcom GFA-5500 2-Channel Amplifier
Corded volume control up and down in volume by itself
I have/had the same problem. Frustrated with the lack of even a make shift solution on the internet I took matters into my own hands. This is a partial solution (as completely fixing it would likely require taking it apart and replacing parts, soldering, etc.) and it might not work for everyone.
Here's what I did...
I cut a small piece of paper a little over 1 inch long and about 1.5 cm wide. I folded it vertically and, using tweezers, wedged it into the space between the dial knob and the surrounding grey plastic. Picture here -> http://imgur.com/8roA2.jpg
It increases the friction between the knob and the plastic and since I've done it I haven't had the random volume jumps. Hope it works! If it does, spread the word because I know a lot of people have this issue.
-Sean
Apr 29, 2009 | Creative Labs I-Trigue 2.1 3300 Computer...
Amp volume problem
Sounds like you have a bad or dirty gain potentiometer. Try turning the gain up and down with the volume at a moderate level. If u hear static, it is possible the potentiometer is bad or dirty. Replace with one of the same value and see if that solves your problem.
Jul 15, 2008 | Rockwood Car Audio & Video
Hafler dh220 power amplifier left channel distorsion
Sounds like your Power FET's are gone. Take it to a shop that specializes in high end or vintage gear. ....good luck...Rob
Dec 21, 2007 | Audio Players & Recorders
593 people viewed this question
Top Boka Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Boka Audio Player and Recorder Expert? Answer questions, earn points and help others
