Question about Alpine CDE-9846 CD/MP3 Car Stereo
No sound from front speakers during CD operation.
There is no sound from the front speakers with my Alpine CDE-9846 while listening to a CD. However, while listening to the FM tuner, the sound works fine all around. The car I bought last week had this deck installed.
Any suggestions?
  • borgy2112 Sep 26, 2008
    the radio works fine as soon as I put in a cd I only get front speakers.
    no external amp
  • 111 Answers
I think you are using an external amplifier,if this is the case,you may be using the wrong remote wire for the amp.
Alpine use two blue wires,BLUE (only) this wire is for the pwr antenna and every time you insert a cd, this pwr line cut out.
BLUE/WHITE STRIPE this is the remote wire that you need to connect the remote of the amplifier.
thanks for rating
Posted on Feb 12, 2008
Can i adapt to fit an Aux cord for Iphone?
Yes. You can connect iPhone to Alpine CDE-9846 with help the cable: https://yadi.sk/i/otMTAdpsqyzyr
Apr 05, 2016 | Alpine CDE-9846 CD/MP3 Car Stereo
Alpine cde-9842 clock set
  1. In the Clock priority mode, press and holdTITLE for at least 2 seconds while the time is displayed.The time indication will blink.
  2. Turn the Rotary encoder CDE-9846 only) or press "up" and "down" (CDE-9842 only) to adjust the hours while the time indication is blinking.
  3. When the hour has been adjusted, press the Rotary encoder (CDE-9846 only) or press MODE (CDE-9842 only).
  4. Turn the Rotary encoder (CDE-9846 only) or press "up" and "down" (CDE-9842 only) to adjust the minutes while the time indication is blinking.
  5. The time is automatically set 5 seconds after the minute adjustment.
  6. The time can also be manually set by pressing the Rotary encoder (CDE-9846 only) or press MODE (CDE-9842 only).
Download Alpine CDE 9842 Manual
Feb 05, 2013 | Alpine CDE-9846 CD/MP3 Car Stereo
Alpine CDM7857 how do I get radio in clock set mode?
press and hold clk button for 3 seconds till it flashes then press the h for hours to set and the m for min to set after you set the lat setting it will auto save the time.
May 05, 2011 | Alpine CDE-9846 CD/MP3 Car Stereo
I can set the hour but I can't figure out the minute settings on the clock.
Setting Time
1 In the Clock priority mode, press and hold
TITLE/ for at least 2 seconds while the time is
displayed.
2 Turn the Rotary encoder (CDE-9846 only) or
press 4 and 3 (CDE-9842 only) to adjust the
3 When the hour has been adjusted, press the
(CDE-9842 only).
4 Turn the Rotary encoder (CDE-9846 only) or
adjustment. The time can also be manually set by
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9846
only) or press and hold MODE (CDE-9842 only) for at least 2
seconds after setting the "hour." Minutes will reset to 00. If the
display shows over "30" minutes when you do this, the time will
advance one hour.
Apr 12, 2011 | Alpine CDE-9846 CD/MP3 Car Stereo
Jus got my second-hand alpine cde-9880r,dont know how to change display color..any help?plz
http://www.alpine-electronics.co.uk/fileadmin/user_upload/manuals/car_audio_manuals/CDE-9880R/OM_CDE-9880R_EN.pdf
On page 20.
Mar 06, 2011 | Alpine CDE-9846 CD/MP3 Car Stereo
I have an alpine stero cm5804 and need a service manual.
simple google alpine audio.com look for support the first thing is manules its strat forward or go to google and google http://valt.alpine-usa.com and its om_cde-9846.pdf
Jul 08, 2010 | Alpine CDE-9846 CD/MP3 Car Stereo
Can't set the clock
Pasted from the manual:
displayed.
press
up or down arrow (CDE-9842 only) to adjust the
(CDE-9842 only).
press
Oct 15, 2008 | Alpine CDE-9842 CD Player
Alpine cde 9846
which "sub level" are you talking about? dB? or gain? either one, you must open your am and check the variable resistors ("volume" knobs) with a multimeter
Dec 16, 2007 | Alpine CDE-9846 CD/MP3 Car Stereo
Alpine car cd player has no volume
It's possible that you have a shorted speaker wire. If one of the speaker wires is pinched, grounded or shorted it will cause the deck's internal amplifier to shut down. The easiest way to check is with a multimeter's resistance function. Remove the CD player and unplug it. Set your multimeter for "resistance" or "continuity". Attach the black probe to chassis ground; you can use the black ground wire in the deck's harness, clean dash metal, or the outer ring of your cigarette lighter. Use the red probe to test each of the speaker outputs in the harness: white, gray, green and violet. If you find a speaker wire that shows any continuity with chassis ground, then that's the cause of the problem. A speaker with a damaged voice coil may also cause the deck to shut down. To test this, probe the positive and negative leads of each speaker and test the resistance between them. For example, to test the left front speaker you'd put the red probe on the white wire and the black probe on the white/black wire. Each speaker should read a minimum of 3 ohms of resistance. If you get a lower reading then it might be causing your problem. If you don't find a problem with any of the speaker wires, then chances are the deck's internal amplifier has failed.
Jun 08, 2007 | Alpine CDE-9846 CD/MP3 Car Stereo
Car Audio & Video Logo
164 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
