Question about AOC 19LVWK LCD Monitor
AOC monitor hooked up to a laptop
Monitor doesn't detect the signal
  • 50 Answers
Be sure to have the monitor connected before you power up the laptop. Also, check the laptop manual to see if there is some sort of key combination that enables the external monitor. You might also be able to find such a key combination by looking at the actual keys to see if you have one that also has an icon of a monitor or the letters CRT on the individual key. Typically, you would press this key while holding down the Fn or similar key to invoke the external monitor.
Posted on Feb 11, 2008
AOC 2036S won't connect to laptop
Is the cable working? try reducing your laptop screen resolution and connect to your monitor. Your monitor may not support full hd resolutions....
Jan 09, 2014 | AOC 2036S 20 INCH BLK LCD MONITOR
We have purchased two e950Sw LED 18.5 monitors to replace the crt monitors on two of our computers. Old monitors worked fine. Both of these monitors when hooked up get the "No signal" message....
Your old monitors might have had a higher screen resolution or and incomparable resolution for your new monitors.
Probably the easiest way to get them to work is to plug the old monitors in then go to your control panel / display and set the resolution to 1366 x 768 as this is the native resolution of the e950Sw LED.
Chris
Jul 08, 2011 | Computers & Internet
(external monitor AOC LM765 flickers white lines) My laptop screen is damaged. I plugged an external monitor (AOC LM765 via RGB), works fine for the past three days but suddenly ghostly lines appear. Any...
Hook up that monitor to another laptop or computer. If it works then its an issue with the vga port on your laptop. If the monitor still shows those lines then you know for sure the monitor is bad and it will have to be replaced.
May 15, 2011 | AOC LM765 (Silver) 17" LCD Monitor
New AOC monitor. No sound . when i insert dvd which was in the package it just promotes AOC products
Did you plug the sound sable into the audio out port on your computer?
The VGA and DVI monitor cable/plugs do not have sound capability so if there are speakers on your monitor they need to get the sound signal through a separate wire.
HDMI can send sound so if your monitor is hooked up via HDMI it should be able to pass sound as well (at least in most circumstances).
Mar 12, 2011 | AOC Monitor
I JUST BOUGHT A NEW AOC F22 MONITOR, BUT IT GOES BLACK , THE POWER IS ON YET I CANNOT SEE ANYTHING, HOW CAN I SOLVE THIS PROBLEM?
If the monitor is black either the computer is not sending signal to the monitor or the monitor is getting the signal and its broken.
1.) does the old monitor or another monitor work with the computer you have. if yes your monitor is prolly broke since there is not much to a monitor they automatically detect signal as soon as its turned on.
2.) if the monitor doesnt work the old one then your computer is the issue and it can be a lot of things can cause no video
Mar 03, 2011 | AOC F22 Monitor
I bought an AOC 2036s monitor in the usa, came back to australia to connect it to my laptop as a second screen. yet it wont seem to work, i keep getting no signal. the box saids compatible with XP, yet...
USA mains equipment operate on 110 volts. Unless the AOC monitor can operate on multi voltages ie 110 to 240 volts, when you connect 110 voltage equipment into 240 volts mains in Australia you most likely will damage the AOC monitor.
To operate equipment that has been designed for 110 volts, you need to purchase a step down transformer from 240 to 110 volts that has suitable wattage rating for the AOC monitor.
Feb 24, 2011 | Computers & Internet
I have aoc lcd monitor, but no display and always orange the swicth botton. what is the problem of my lcd? can you help me? thanks..
It sounds like there is no signal to the monitor. The computer you have, does it work if you hook up another monitor? Have you taken this monitor to maybe a friends house or neighbor? See if it works. If it does; there may be a problem with your computer's video. If the monitor does not work; the issue is the monitor. It will then need to be replaced.
Jan 29, 2011 | AOC 193FW LCD Monitor
Getting a no signal when hoioking up to video card.
hook a different montor up to the same card and see if you get a signal. if you do change the input on the monitor not getting a signal. if this does not make the monitor get a signal your video input on the monitor is bad and needs o be replaced or repaired
Dec 26, 2009 | AOC Monitor
Bought Samsung 2233BW Monitor, hooked the two plugs, power and DV1 cord started computer and switched on monitor, NOTHING HAPPENED. Silly thing just unhooked Samsung and hooked back up the AOC monitor no...
You might need to go into the monitor's setup menu and select the digital input. (That's DVI, by the way, for Digital Video Input, and not DV1.) Some monitors automatically detect the input but not all of them. Obviously, this doesn't apply if the Samsung has only a DVI input. It might also be necessary to tell the video card to turn on the DVI output. You can do this with your old AOC connected and use the video setting utility supplied with the video card.
May 22, 2009 | Computers & Internet
Color coding in signal cable for AOC CRT monitor
what do you meen by (color coding in signal cable for AOC CRT monitor) i might be able to help you if you can explane what you meen thank you.
Apr 22, 2009 | AOC CT720G 17" CRT Monitor
AOC 19LVWK LCD Monitor Logo
142 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
