Printing problem with brother printer MFC 3320CN
On the screen says pls open cover and does not print
  • kingston27 Mar 04, 2008
    always say( pls open cover) does not print
  • 50 Answers
Open up the printer and check for a jammed page stuck inside. If there is one, remove it and then close up the printer and try again.
Posted on Feb 11, 2008
The problem is: error machine 41 can I resolved? Al
This is a common issue on Brother printers. It means there is a problem with the print head.
Please see this link for more details:
http://www.fixyourownprinter.com/forums/inkjet/27620
If your printer is under warranty then you should be able to get it replaced.
Hope this helps,
Please rate my answer, thanks.
Chris
Mar 02, 2011 | Brother MFC 3320CN Printer
What does it mean when it says Drum near end
Order a new drum, part number DR520, from an office supply store or Brother (http://welcome.solutions.brother.com/bsc/public_s/id/us/us/en/monolasermfc/mfc8460n_all/c_o/index.html?reg=us&c=us&lang=en&prod=mfc8460n_all&cao=dr ). The drum transfers the toner onto the paper and has a finite lifetime - approx. 25000 pages (1 page/job). Change the drum when the print quality decreases or the message changes to replace drum or drum end.
To replace, open the front cover and remove the drum and toner cartridge assembly (wait until the machine cools if it has been printing). Avoid the electrodes on the assembly. Hold down the lock lever and take the toner cartridge out of the drum unit. Unpack the new drum and put the toner cartridge in the new drum (when it is locked the lever should lift automatically). Place the assembly back in the all-in-one. Do not close the front cover. Press Clear/Back on the control panel. The LCD should ask "Replace Drum?". Use the up/down arrows to select 1. Yes and hit OK. When the LCD shows "Accepted", close the cover.
I hope this helps.
Jun 03, 2010 | Brother MFC-3320CN Plain Paper Inkjet Fax
How to print and evelope on mfc -7840 brother printer
You need to use the manual feed, which is above the tray and open the back cover when printing envelopes.
Feb 22, 2010 | Brother MFC 7840W Printer
My fax machine says pls open cover
Very likely you have some paper stuck in the printer. Try to lool for it and remove the stuck paper
Jan 17, 2009 | Brother MFC-3220C Plain Paper Inkjet Fax
Unable to print and copy
pls check the trigger switch of the back cover
Oct 16, 2008 | Brother MFC-7420 Printer
Can't install new ink, can't do anything
open the cover of your printer and ink cartridge will move to the left therefore allow you to change your ink
Apr 16, 2008 | Brother MFC 3100C All-In-One InkJet...
Don't know how to print
If the driver installed correctly you should just be able to open up the file you want to print. Then go to File, Print and select the Brother printer. Click print and see if it works.
Brad Nelson
Mar 15, 2008 | Brother MFC 3420C All-In-One InkJet...
Printer won't print
...and what else does the lcd display say?
Jan 10, 2008 | Brother MFC 420CN All-In-One InkJet...
82 people viewed this question
jasbo
jasbo
