Question about GE (GTS16BCS) Top Freezer Refrigerator
GE model GTST2BPLWW
FREEZER STOPPED AFTER VIBRATING HARD  FOR SEVERAL DAYS.  THE BOTTOM REFRIGERATOR PART STILL WORKS AND THE NOISE HAS STOPPED.   THE FREEZER WILL NOT WORK
  • 5 more comments
  • lorilee Feb 12, 2008
    There is sound but I do not know if it is a fan.  May be from fridge below which still works
    Must be the fan then.??? Where is the fan cover?  Ice is forming on the roof of the refrigerator unit now -- which is new,  ( I have the unit set on cold.)    The freezer section floor is now quite cold, which it was not before.   But no ice or  ice cubes are forming, The vibrations, if I recall I felt strongest on the freezer floor.   Thansk so far
  • lorilee Feb 13, 2008
    Inside freezer?   Inside is all of a piece --nothing to remove   There is a curious plug-like object protruding  on the lower back  freezer wall left side   It looks much like a raised socket and one sprocket (?) of this bject is showing red
    forgot to say that the sound seems more like a motor than a fan to me.  There is a small one inch plastic circle which comes out -- but contains a circular piece of what appears to be plastic foam (like packaging)
  • robert samples May 11, 2010
    do you hear a fan running in the freezer
    President:
  • 1,314 Answers
They all have fans the freezer does all the cooling for the whole unit there is nothing in the bottom unit that cools the freezer fan blowes air from the freezer down to the bottom and draws air to the top if you dont hear the freezer fan running and there would be no doubt in your mind if it was then pull the fan cover and see why and let my know hold my rating till we are done please
Posted on Feb 12, 2008
  • 1 more comment
  • robert samples Feb 12, 2008
    here
    look in the top of the freezer on the back wall you will see a cover the rectangle plastic peice covers the fan see if you can take that off
  • robert samples Feb 13, 2008
    that should be your unit see the panel at the freezer with the air chanel and the round hole thats where you need to go let me know if yours looks like that
I have a KitchenAid Refrigerator Model Number: KBFC42FTS. Bottom drawer freezer over cools -10 degrees.
Does that unit have a low temperature monitor built in? Maybe that is what is making the noise when your temps dip to -10 degrees. Actually, that is great because the lower the temps the longer you can keep food in the freezer so I would not be overly concerned about that aspect. BTW, have you tried to isolate the source of the humming noise?
Sep 19, 2017 | KitchenAid Refrigerators
That's interesting, -10 or colder is too cold and something is defiantly going on. This unit is controlled by a mulitple control boards, temperture sensors and other components. Question, what is freezer temp set at? Try increasing it by 3-4 degrees and see if that changes anything. Beyond that, I'm going to change the temp sensor first before doing any of the control boards. #29 is the temp. sensor. Good Luck
Freezer on bottom is cold,refrigerator on top is warm. 2 days before failure there was a vibration noise intermittently between fridge and freezer that stoppped if freezer door was shut hard
This is a little strange to hear but something caused the vibration. Closing the doors hard or soft may make big changes in sound because of pressure change. I just want to know if the compressor is purring away without overheating. Anytime there is a restriction in ventilation the evaporator fan will struggle to push the air to the freezer and enough to refrigerator side to maintain safe temperatures. On the bottom even if the fan stopped the bottom would work because it is below and cold is heavier than warm. I will look over your parts breakdown to see what vent, dampers or fans that may cause this, work with me on this and I will help you solve this. Thanks Sea Breeze
Jan 21, 2010 | GE Profile PDS20SFS Bottom Freezer...
GE fridge has loud clicking noise; model freezer on bottom.
The problem is the main control board on back of refrig . Relay bad and clicking . Have to replace the complete board .
Jul 23, 2009 | GE GBS18KBM Bottom Freezer Refrigerator
WHISTLING NOISE DAY AND NIGHT IN FREEZER SECTION REFRIGERATOR GE MODEL GSS201BPDWW WHEN MOTOR IS WORKING
The whistling is caused by the air circulating fan located just behind the light. It is easily accessed by removing the light cover and the two small hex screws above the light. To stop the whistling I simply turned the freezer off and pulled the fan cover out slightly to reveal the fan blades. I then pushed the blades down, toward the bottom of the until the blades stopped and i could feel the shaft slightly protruding from the top of the blades. Repositioning the blade has stopped the incessant whistling. Hope this helps!
Apr 18, 2009 | GE Refrigerators
Refrigerator not working
Hello bobbie50,
Welcome to Fixya,
You said, After making a louder than usual grumbling noise several times today, my refrigerator is no longer cold (freezer too). Please tell me I don;t have to buy a new one. my refrigerator is not working properly. The freezer keep thing cool but will not freeze. the bottom part does a little cooling ,but not like it should.
Help me with a little info.
What is the model # and the year or age of your fridge?
Let me know right away. I'm here for you!
Huuum
Aug 04, 2008 | GE Hotpoint Top-Freezer Refrigerator
Ge fridge
you have 2 fans one underneath by compressor ,one in freezer make sure one in freezer is running
Dec 14, 2007 | GE GDS20SBS Stainless Steel Bottom Freezer...
GE (GTS16BCS) Top Freezer Refrigerator Logo
166 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
