Question about Motorola Mobility HS850 Consumer Headset
Sync a headset
Got a new phone and have the motorola hs850 and need help conecting to my phone which is a nokia 6085
    Problem Solver:
Do you mean pairing it.
when in off position push the central button until light comes on, open boom and the light should stay on.
the phone should now pair with it
Posted on Feb 24, 2008
Lost instruction manual for my Hs850 headset. need to sync to different cell phone device, if possible. Blackberry curve 8520.
is on the Motorola webpage.
check there
http://www.motorola.com/staticfiles/Support/Mobile%20Phones%20Accessories/HS850/US-EN/_Documents/Static%20Files/HS850_UG.pdf
Oct 31, 2010 | Motorola Mobility HS850 Consumer Headset
Need to sync my motorola n136 to my phone
Your headset may also be called a HS850 (may look different) but the instructions would be the same. Instruction manual is here:>
http://www.motorola.com/mdirect/manuals/HS850_%209489A97O.pdf
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Nov 05, 2009 | Motorola Mobility Bluetooth Hands Free...
Sync to HS850 motorola - to blackberry
go to the sync option in your phone and turn bluetooth or headset on and then if its a bluetooth hold all the buttons on it downuntil it beeps or lights up
Sep 09, 2009 | Motorola Mobility HS850 Consumer Headset
How do you know what model your motorola headset is?
If you have a Playstation 3 or a Phone, sync it in to them and then on the phone or PS3 it show all the info you need about the headset
Dec 29, 2008 | Motorola Mobility HS850 Consumer Headset
HS850
make sure the ac adapter isnt bad
Jan 19, 2008 | Motorola Mobility HS850 Consumer Headset
Nextel I870 phone and my HS850 blutooth
hold down hook button until blue indicator goes solid blue
(mic FOLDED IN) flip out mic quickly and go to settins on phone and select bluetooth or connections and select find/add bluetooth device and select bond or pair enter passcode 0000.
select done and blue light should now be blinking indicating it was connected
Jan 09, 2008 | Motorola Mobility HS850 Consumer Headset
Pairing Motorola RAZR with the HS850
No, living outside of your cellular "home area" has nothing to do with the bluetooth pairing. You're problem is a common problem. Lots people have this problem you are not alone. So, here is what I suggest. 1. Make sure both the headset and the phone are fully charged. 2. Delete the "device" from your phone. I mean precisely that. Go into you cell phone's bluetooth settings and erase your "HS850" from it. 3. Try re-pairing it. Put the phone and the headset in pairing mode and allow it to sync. This should do it. I always works for me. You usually only need to pair once and every time you use the headset all you should have to do is connect it. I hope this works for you. Good Luck.
Aug 02, 2007 | Motorola Mobility HS850 Consumer Headset
Can't connecto to headset again...
You are not alone in this endeavor. A lot of people have this problem. So, here is what I suggest. 1. Make sure both the headset and the phone are fully charged. 2. Delete the "device" from your phone. I mean precisely that. Go into you cell phone's bluetooth settings and erase your "HS850" from it. 3. Try re-pairing it. Put the phone and the headset in pairing mode and allow it to sync. This should do it. I always works for me. You usually only need to pair once and every time you use the headset all you should have to do is connect it. I hope this works for you. Good Luck.
May 09, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility HS850 Consumer Headset Logo
112 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
