ON the camera, turn mode selector to SCN mode, click MENU button, scroll down and select the "briefcase" icon. Inside it, you will find a "Hammer & Spanner" icon on the left, as the 2nd one from top, select it, and then select INITIALIZE, then center button.
SOURCE: How do I reset my camera (Sony DSC-H20)to original
Press the reset button on your camera this will be close to the pin where you can connect the power supply to your camera. The button will be a small hole use a pointed object (like a ballpoint pen) to press and hold the reset button for 2-3 seconds. After 3 seconds release the reset button .
Now your camera is reset to factory settings .
Hope this helps .
Performing a manual power reset may help:
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Reset the camera to factory specifications to try resolving the issue.
Thanks for resolving the issue.
