posted by trujilloed on Feb 11, 2008
okidata c3200 prints fine but message keeps coming up, "needs new drums". How to fix or determine if drums are bad? thanks.
Best Solution
posted on Feb 12, 2008
Check your page count, drum life on a C3200 is roughly 15000 pages. This information can be found on the information menu map.
Information Menu
Menu
Item
Default Setting
PRINT MENU MAP
EXECUTE
Prints the MenuMap (menu listing) with current settings shown. Information about your printer is also
shown at the top of each MenuMap page.
Life Expectancy
Toner Cartridge
Life expectancy approximately 1,500 pages, assuming about 5% coverage, which means that 5% of the addressable dots in an image are printed with this color of toner. See Toner Cartridge..
Image Drum
Life expectancy approximately 15,000 pages, assuming an average of 3 pages per print job. If the average print job is longer than this, the image drums could last longer, but if the average print job is shorter, then image drums will be used more quickly. See Image Drum.
Transfer Belt
Life expectancy about 50,000 letter-size pages. See Transfer Belt.
Fuser
Life expectancy about 45,000 letter-size pages. See Fuser.
Information Menu
Menu
Item
Default Setting
PRINT MENU MAP
EXECUTE
Prints the MenuMap (menu listing) with current settings shown. Information about your printer is alsoshown at the top of each MenuMap page.
Life Expectancy
Toner CartridgeLife expectancy approximately 1,500 pages, assuming about 5% coverage, which means that 5% of the addressable dots in an image are printed with this color of toner. See Toner Cartridge..
Image Drum
Transfer Belt
Fuser
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for OKI C3200n Led Printer
Email this problem
Email this problem
Can you Help with these Printers problems?
Oki C3200n Says Order K Toner...
I've just installed a new K... Answer This...
Error Code 542: C and a bad...
When printing the rollers start... Answer This...
Repair Service
Find Printer Repairman Near You:
