Question about Hitachi 53FDX01B 53" Rear Projection Television
S video displays, but Component video is intermittant
My DVD player has component video and S-video outputs.
If I connect my DVD player to the TV via the S-video the TV displays perfectly. However, if i connect the same DVD played to the component inputs, the TV will display for a while then go blank. After a while the display returns and then goes blank agin. DVD is 480p..
Any ideas?
  • dar01 Feb 12, 2008
    DVD is fine, it outputs Component video to other TVs just fine.
    DVD previously worked fine with this TV in S-video or component mode.
    Now when I select the component video inputs, it displays just fine for a moment correctly then black screen as if no input, comes back, then black, repeats, etc.
    TV reacts to other component video sources (Cable TC box, different DVD player) the same when connected to TV. S-video OK, Component unstable.
  • dar01 Feb 13, 2008
    Yes, Cables are fine. Used them on another DVD/TV with component input and they are just fine.
    Y signal when applied to normal video input displays proper black and white display. However, when connected to the correct component input, it appears that horiz sync cannot be obtained.
    Master:
  • 788 Answers
Check the options meny of your DVD player, there might be some settings for configuring the component output. I would also see of this is happening for all component devices (borrow an Xbox 360 or another DVD player), if it does that it may be a problem with your TV.
My mother has a cheap DVD player and when it is connected by component to there brand new Sony LCD TV the picture is tinted pink, I have determined that it is the DVD player that is causing the problem so they are sticking to S-video until they get a new DVD player.
Posted on Feb 12, 2008
  • Dean Joly
    Dean Joly Feb 12, 2008
    Did you try different cables?
    Genius:
  • 3,587 Answers
Shall we assume that the DVD is fine, before addressing the TV issues? Does it work with any other device or component? Seems that if your S Video is clean, then it's just a matter of refining whether your DVD is as well. Check that, and let us know.
  • Patrick Michaels
    Patrick Michaels Feb 12, 2008
    ok..have you tried another set of connecting cables. sound a bit like a bad ground on one of them, perhaps.
  • Patrick Michaels
    Patrick Michaels Feb 13, 2008
    so your component input is totally unhappy, is that fair? I suspect that you are working with an unhappy system board.
No video from AV1 channel connected to a Toshiba DVD player via Component to Sharp Aquos TV via HDMI. Audio is fine via Optical cable.
Usually you cannot mix and match sources and outputs. In other words, if you're using component to connect from DVD player to a receiver, you have to also use component to connect from receiver to TV. Input and output MUST be the same - both HDMI or both Component.
Apr 19, 2015 | Sharp Audio Players & Recorders
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
I have a Denon AVR2307 to which is connected,via optical audio and component video a DVD player/recorder and this works well but in order to take some of the work off the player part I've bought another...
HDMI signal from DVD can not be down converted to analog component signal.
Connect your new DVD to a component input 1..4. Make sure that component input assigned to desired input (dvd/vcr/sat/) (setup - input setup - input - component assign - component x etc). Connect coax output of DVD to coax x input of the receiver and assign it (setup- input setup - "input" - digital assign ..). Probably you need to setup DVD output resolution to 720i or 720p in dvd setup menu.
Sep 09, 2010 | Denon AVR-2307 Receiver
I just bought a yamaha rx-v365 receiver and hooked to my cable box via a hdmi and optic audio cable. this is working fine but i cant get a dvd player to work via a component and coax audio cable. neither...
Make sure that the DVD player is connected into the correct inputs on the receiver and that the receiver also has the correct input selected to play. If your TV also has component video inputs it is best to connect the player directly to the TV. Otherwise, make sure you have the TV connected to the receiver via component video out.
Nov 25, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Need to hook up a TV,VCR-DVD player,and CD player
Progressive scan video output would be available on Component Video terminals of dvd player so set connections between TV and dvd player via Component Video cable.
Please intimate model and brand of product that you need instruction manual.
Thanks.
Aug 31, 2009 | Sanyo Cinematic Progressive Scan DVD...
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
Upconversion to 1080i playback
Hey smittybd,
According to information provided by the manufacturer, this specific model DVD player is only able to provide upconverted 1080i images via its HDMI output and a maximum 480p resolution using its component connectors. Please keep in mind that while component cables are able to support 1080i and 1080p resolutions, not all hardware (TV's and DVD players) will support these resolutions through component connections.
If you're having difficulty locating a model that specifically supports 1080i resolution images through its component connections, you may wish to try visiting individual manufacturers' websites for more information. Some companies (such as Sony) will provide detailed information regarding what each type of connection is capable of in their owner's manual documentation.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 15, 2008 | Sony 36IN TV Stand Designed for Model...
No component video output
Hope this helps
The Yamaha HTR-6030 offers two types of video monitor output: Component and Composite. You may need to connect both types to your television as the HTR-6030 does not have composite to component video conversion. In other words, to view your VCR on your TV, you need to use the composite video monitor connection. However, for a DVD player or other source that has component video connections, use the component video monitor output to your TV. If your TV has both types, you simply switch between the two with your TV remote to access the proper video monitor output signal from the HTR-6030.
Jan 23, 2008 | Yamaha HTR-6030 Receiver
Sony KV-27FV310
Component In is not converted to composite out (yellow)
TV monitor out normally goes to A / V receiver in......T.
Nov 18, 2007 | Sony FD Trinitron WEGA KV-27FV310 27" TV
No color when switching to component cable
To Change DVD Player Video Output to Progressive Scan: With your DVD Player turned on, and your TV turned on, press and hold the PREV/VIDEO button for at least 3 seconds (this puts you into Video Output mode). Press the PREV/VIDEO button to access different video output options. Each time you press
PREV/VIDEO, the type of video being displayed appears next to the Display menu. Look for PSCAN on your DVD player display panel. At this time, your progressive scan on TV should be working.
Oct 18, 2007 | RCA DRC233N DVD Player
Hitachi 53FDX01B 53" Rear Projection Television Logo
66 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
