I'd start with one of these and move on to the next.
Fuel
Spark.
Is it getting fuel? You should have an "in tank" electric fuel pump. When you turn the key halfway (just before turning the engine/starter over), you should hear the fuel pump prime. Easy way to check is to look in the throttle body while someone turns the key to the "on" position. You should see/smell the fuel. You can also listen to the gas tank while the key gets turned. You should hear the fuel pump run.
To check spark, pull a spark plug out, put it back on the plug wire and rest the electrode end of the plug up against the engine or exhaust manifold and have someone turn the engine over. You should see the spark plug firing. Don't hold the plug or wire while doing this. You'll get zapped if it's working ok.
If these both check out ok, then take a look at your firing order. If it's off by a significant amount, it may not fire. I've seen this happen when a cap/rotor/wires were changed and the wire/rotor was not positioned on the correct cylinder. (Most of the time they will at least fire or backfire, but either not stay running or run REALLY badly if the firing order is off.
Testimonial: "Thanks for the advice. I don't think it has to do with the firing order. the distributor and rotary were changed after the problem.I'll chk. firing."
100,000 miles on odometer.
How many miles are on the car??? Sounds as if your ignition switch is faulty, but it's hard to tell with the info i currently have.
