Question about Kitchen Ranges
Electric spark for gas is non stop after cleaning
I have an old GE gas range top. I just cleaned the burners and around the burners. Now there is a spark, like the same sound when you light the burners, that is clicking systematically on each burner. It has not let up. Is there anything simple I can do to rectify this?
Thank you
marcie@marciehunt.com
tel: 415 279-9227
  • Ms Clean Feb 12, 2008
    It has been about five hours and it is still not working. However, who knows, maybe tomorrow, if that is the cause.
    I apreciate your input.
    Thanks,
    Marcie
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 848 Answers
Electric spark for gas is non stop after cleaning? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
742GL2 715G2538 3 LEG Lenovo ADTV742GL2 Power Supply Backlight Inverter...
Posted on Jan 15, 2015
HI I am having the same problem and I think it is caused by water getting into the burner knob switches. I have just unplugged the stove and am going to wait for it to dry out.
Posted on Jan 06, 2009
    President:
  • 1,314 Answers
It will stop when it dries outun plug it for now
Posted on Feb 11, 2008
I want to clean under the gas burners on the top of my 10 year old ggGE Gas stove. Can I lift up the top?
first check for screws or rivets holding the top on some models you have to unscrew or drill out .
May 24, 2014 | GE 30" Self-Cleaning Freestanding Electric...
Electric spark starter on one of the burner runs continuously
check the spark head on that particular burner first for dirt,they all need to be clean to recognize the flame after ignition and sense the flame to shut off the sparker module after ignition,and if not you will need to replace the spark module that fires the sparkers itself,but try cleaning sparkers and underneath where the wires connect to the sparkers first for contamination,its cheaper than starting to replace parts
Dec 31, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Range top ignighters sparking
One of your "switches" to your burners is shorting causing unit to spark when in the off mode, or, you may have a bug problem, bugs have made their way into the spark module.
1: if no bug problem, disconnect stove from electricity, lift top up, remove all of the single connections to each switch to top burners(make sure they don't have any bare wires touching the frame), then plug unit back in, if still sparking then replace module.
Oct 01, 2009 | GE Profile 30" Self-Cleaning Slide-In...
Pilot on GE stove keeps popping non-stop
As far a "popping" do you mean the igniter on the cook top "clicking"? Did you clean the range and use too much water? If water gets into the igniter switches they will short out and constantly click. Also if the polarity at the electrical plug you can get what is called "ghost spark" so make sure that the polarity is correct at the electrical outlet. Each gas control valve has a switch that turns on the igniter when the knob is in a certain position and they are all wired in a sequence. One of those switches may be shorted out or have a loose wire(range dis-assembly required to inspect). Do you visually see a spark at the electrodes of the burners or do the burners ignite? If you cannot see the spark then there may be a grounding issue and possible loose wire.
Sep 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE 40" range griddle
You will have to check GE. With a model this old, it will be hard to find a replacement.
Feb 11, 2009 | GE 30" Self-Cleaning Freestanding Gas...
Want to clean under stovetop
Hello
welcome to Fixya,
This stove has sealed burners and there is no need to lift or clean under anything except the burner caps.
You can not get inside the top and you can not lift the top like the old pilot stoves!
When you clean the burners and around rings do not spray or saturate the are and or the igniter element that creates the spark.I'll be back in a moment with your user manual.
first what is the complete model number of your range as written on the sticker in the door jam of the storage compartment down below. left side!
Huuum
Dec 15, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
GE gas stove top igniters won't stop clicking
My wife just called me with the same problem - all 4 starters are clicking repeatedly - which started while the range was being cleaned.
From a Google search, this is what I found. Don't know if it will solve our issues, though wanted to share as it sounds like we may all be suffering from dirty starters (electrodes).
My surface burners keep "clicking" even after the burner is lit. There are a few things to check for.
And, to check the model number, look at the various places pointed to in the upper left of this diagram. http://www.applianceaid.com/newpics/range-model2.JPG
Oct 18, 2008 | GE Profile JGP636 Gas Cooktop
Electric starter for Electric stove
I think you mean you have a gas range with electric ignition. When you turn a burner to light, all burners should spark. The most common problem is boil overs have happened on those two burners. Take the burner head off for sealed burner ranges and clean them out. For non sealed burners, the little holes toward the center side of the burners need to be cleaned. You don't have a model listed, so I can't be real specific.
Aug 15, 2008 | GE Spectra JBP78 Electric Kitchen Range
Electric spark for gas range burner is non stop
Turning any knob starts the spark via a switch behind each which should disengage when the (any) knob is turn further.
One of your switches is stuck.
I think you should be able to remove the range-top for access and find the offending switch.
It is probably gummy from a spill and is no longer in solid contact with the cam that operates it.
A solvent/lubricant such as WD-40 sprayed on the plunger of the switch once you can see it and operating the knob back and forth should free it up.
It might be wise to turn off the gas supply while tinkering with the range - blow your house away and the range won't matter. :-(
Jun 19, 2008 | Viking VGSC306-4B Gas Kitchen Range
Gas oven range
The flame acts as a conductor when the burner is on. Clean the burner and make sure it's got good grounding. Clean the ignitor too. Re-position the ignitor to make sure it is inside the flame.
Aug 09, 2007 | GE JGBC20 Gas Kitchen Range
Kitchen Ranges Logo
250 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
