Question about Philips GOGEAR SA6045 MP3 Player
Philips mp3 player sa6045
Hi guys.
Just got this new and plugged into computer for charging. Hope I can explain myself properly.
Two things:
message on screen says "OK to disconnect" - not fully charged - so don't understand this message, as just before that it said "do not disconnect" on the screen.
when I first plugged it in, message on task bar said new hardware found but it is not showing that on icon which when you click on it shows all hardware connected - ie new hardware doesn't seem to exist. Worried that just pulling out connection when I think it is fully charged, will damage something eg when I plug in flash drive - message shows new hardware present = e drive, then when I want to remove it, I click on icon on task bar and message says "safe to remove".
Why is this apparent with my new mp3 player?
Thanks Trish
  • 476 Answers
This player shows the "Do not disconnect" message when it is doing something critical such as transferring tracks or updating firmware, which could corrupt the player if disconnected part way through.
The player shows the "OK to disconnect" when it is idle. As the message says, it's ok to disconnect, as the player will not corrupt if disconnected when it is idle.
These messages mean that the player does not need the "Safe to remove" procedure.
It is ok to disconnect part way through charging. Also the player will condition the battery once it is fully charged, so it's ok to leave it charging.
Occassionally batteries can "memorise" when constantly disconnect and reconnected without fully charging and discharging. To help prevent this, fully discharge the player (leave on until dead) and fully charge and condition (leave charging for about 12 hours) every couple of weeks or so.
Posted on Feb 12, 2008
When I try to turn on the MP3 (Philips GoGear Mix) I see a symbol of a battery and then it shuts down. When I plug the MP3 to the computer it shows it is fully charged. What shell I do? Thanks
I have had a GoGear for a while and those things have horrible firmware and are very fragile. I have experienced the same issue myself, so I suggest leaving it plugged in for several hours no matter what the screen says to try and let it charge. It should charge up. If not, try charging via a usb wall charger, which should allow usage of the player while it charges.
Jun 01, 2011 | Philips GOGEAR SA6045 MP3 Player
Does wmv format supports philips gogear vibe
Hi
Philips go gear SA6045 mp3 player supports MWV format files. Please click on this link for details---
Hope this helps...
Daniel
Aug 28, 2010 | Philips GOGEAR SA6045 MP3 Player
I dont kno how to get songs on m mp3 player. how do i do it?
Go to next site to select your country and exact model SA6045:
http://www.p4c.philips.com/cgi-bin/dcbint/cpproduct_selector.pl?slg=ENG&searchtxt=SA6045
Overview support for GoGear SA6045/02 ( UK ) :
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA6045/02&slg=en&scy=GB
Manual for the SA60xx series:
http://www.p4c.philips.com/files/s/sa6045_02/sa6045_02_dfu_eng.pdf
Windows Media Player 11 can be used to transfer songs from the computer to the player.
Use the Media Converter for Philips software for adjusting the files into
proper size and format. Download for Arcsoft MediaConverter:
http://www.p4c.philips.com/files/s/sa6045_02/sa6045_02_mcs_eng.zip
Oct 17, 2009 | Philips GOGEAR SA6045 MP3 Player
Mp3 player plugged in but not charging anymore screen shows empty battery
tr to change your battery with a new one.
let me know what happens next
thanks,
Jun 28, 2009 | Philips GOGEAR SA6045 MP3 Player
Gogear says ok to disconnect, but isn't charging, how do i make it charge?
hi , enter to the website of philips and download the software and new firmware select first you exact model, next quit batteries of your mp3/mp4 player and press the button (bent arrow) all the time until it detects and connect to the computer and run software and choose repair
May 14, 2009 | Philips GOGEAR SA6045 MP3 Player
4mb go gear mp3 player
You can try running a Repair in the Philips Device Manager, but it will probably not work - get a replacement - either through the store or Philips. I can tell you exactly why the msg is coming up, but I've explained it so many times over the last year, i am tired of explaining so many times. just trust me. Run repair - when that fails - get it replaced.
-Tha Mp3 Doctor
Oct 19, 2008 | Philips GOGEAR SA6045 MP3 Player
Help
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Aug 03, 2008 | Philips GOGEAR SA6045 MP3 Player
Sa6045/37 and a new computer = disaster
www.usasupport.philips.com - enter model number, click on the version ending in /37, and click on "software and drivers"
Jun 08, 2008 | Philips MP3 Player
Philips GOGEAR SA6045 MP3 Player doesnt register.
I worked on this thing (sa6045) for three hours................no luck.Finally got a fix.....Go to programs add/remove menu under control panel and delete Philips device manager.Then go to Philips site and download new driver:http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&mid=Link_Software&cat=MP3_PLAYERS_CA&sct=SU00304_SU&grp=PORTABLE_ENTERTAINMENT_GR&session=20080506223817_68.47.250.64&ctn=SA6045/37&dct=PAL&did=AEN&file=/files/s/sa6045_37/sa6045_37_dmr_aen.htm
Install your new driver and be SURE windows media player is not running or trying to sync.If it is running in background philips device manager will not work.Once new driver is installed you can pull up the repair panel and do a hard reset thru software on your Sa6045.
Good Luck
May 03, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips gogear sa6045 mp3 player
enter SA6045 in model number or keyword bar
click on SA6045/37 link on the next page
click on software and drivers on the next page
download device/firmware manager link
Feb 20, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
950 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
