Question about Sony CPD E430 (White) 19" CRT Monitor
Sony CPD E430 19" CRT Monitor Color adjustment
Hello
i have the Sony CPD E430 19" CRT Monitor n i was trying to adjust the colors n the brightness, then the colors n all the screen brightness adjustment got all bad n now i cant adjust it back, i tried to reset it but with no use, i want to get to the default adjustment but i cant find it, please help me with this problem is so important :(
techman
  • 3130 Answers
SOURCE: cant locate or adjust the the TV color
Sorry to tell you my friend, if you do not have the original remote, you cannot adjust the set with the on screen menu. See if a friend or someone you know has a sony tv set that you can borrow one from. Sony does make a universal inexpensive remote I saw at walmart once. That should work too. Good Luck Please dont forget to rate this thread.
Posted on Nov 06, 2006
CoachTim
  • 202 Answers
SOURCE: monitor
Is there still power to the monitor or is the screen just black? Do you hear any sort of sound when it goes black? Does the time the picture goes out vary or does it happen after say "X" minutes/hours everytime? Do you have any power saving software activated that would cause the monitor blank out? Check display properties? Sounds weird but have you checked for any viruses or spyrus nasties? If its hardware it could be many different things. Let me know what happens. Good Luck Tim
Posted on Mar 15, 2007
  • 1694 Answers
SOURCE: bad color on sony kv-36fs16
Possible bad CRT....check video out on C board,video drivers on
A board.........................T.
Posted on Apr 10, 2008
geemarie
  • 876 Answers
SOURCE: color issue
Excuse me I meant COLOR adjustment.
Posted on Aug 19, 2008
  • 1527 Answers
SOURCE: My Sony 60 inch DLP
hello it sound like the green tube has a fault. you will need an engineer to diagnose the fault
regards
shaun
Posted on Dec 05, 2010
Testimonial: "Thanks I appreciate the help"
What are the best picture calibration settings for the sony 4k xbr65x850a tv
Brightness to 40 > 50%, Contrast to 65 > 75% & Color to 30 > 35% must give a good picture. First, try to adjust a good B/W picture, by adjusting the brightness and contrast. After you have got a good picture in B/W, then advance the color intensity, according your viewing taste. Gopakumar Gopalan Google
May 30, 2014 | Televison & Video
How to adjust picture color
To adjust color first of all set contrast and color controls to minimum,adjust the brightness to see clear picture than add contrast to get perfect black and white picture than add color to it for a good quality color picture.
Jan 22, 2011 | Symphonic ST419E TV
My monitor does not have any red color to it is there a way to adj. color inside of monitor. thank you
It is very dangerous to work on tv's or monitors without the proper training. They hold voltage even after they are turned off and unplugged, enough to seriously injure someone. There are however adjustments that can be made once you crack open the casing, but if it has already lost color, it will only continue to lose it if you can ever get it set back right again. You best option would be to acquire another monitor. If you want to try it anyway, there are screws in the back of the metal chassis that adjust color, hue, brightness, and shape, that can be adjusted with a small screwdriver.
Aug 18, 2010 | Compaq MV 740 17" CRT Monitor
Picture is far too large, exceeds screen, colour cannot be adjusted to anything but very bright. Screen now flashes while on line.
on your crt's manual menu you can resize the screen hit the menu button on your screen to begin or you can try the auto button
May 09, 2009 | Sony CPD G420 19" CRT Monitor
Bad color on sony kv-36fs16
Dec 23, 2007 | Sony KV-36FS16 36" TV
Retrace line on monitor
To prevent serious damage and extend the life of your monitor you need to adjust the main brigthness control of it. it is of the LOPT/Flyback transformer inside of your monitor!
check also for cold SOLDER joints on the main pcb and also on the crt neck Board.
Nov 16, 2007 | Sony STYLEPRO CPD-E540 (Gray) 21 in.CRT...
Screen and colors too bright
CRT and LCD will look different when compared side by side. Is your CRT calibrated, or are they right in the sense that they are what you are used to? Also Anyway, you can adjust the colors and light levels from the menu on your screen, and depending on your operating system and graphics adapter you should be able to make adjustments there, too. For windows XP, right click your desktop and select properties->Settings->Advanced. There might be a color management tab. Also, there might be software to help you do this already installed. Look for a program group with the name of your Graphics adapter manufacturer. Very often ATI or nVidia. A few resources to help calibrate: http://desktoppub.about.com/od/visualmonitor/Visual_Monitor_Calibration_Tests.htm http://desktoppub.about.com/od/visualmonitor/Visual_Monitor_Calibration_Tests.htm
May 17, 2007 | NEC MultiSync 1920NX 19" LCD Monitor
Monitor
Mar 15, 2007 | Sony CPD G420 19" CRT Monitor
Monitor Screen Bright with horizontal white lines
I have an emachine 17" Flat Panel Monitor and I accidently touched the Standby Mode on my keyboard and now my menu won't work right. I can't adjust the color enough. If there is anything I can do to fix my problem it would be appreciated.
Thanks
Oct 08, 2006 | E-Machines 17F2 17" CRT Monitor
Sony CPD E430 (White) 19" CRT Monitor Logo
99 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
