Sounds like the heating matrix/element has failed, or some other internal component has failed. If you can return it under warranty, do so. Otherwise you'll have to pay an appliance repair engineer to repair it for you.
clean out lint filter check the vent hose make sure you are getting a air flow out your vent hose if not its blocked inside no air no dry it need air to dry cloths heat only will not dry plenty of air heat quicker drying
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
It's not your heating element. Your venting system is clogged. Like mine was. You'll need to take care of this ASAP and from then on at least once a year. It is a fire hazard. Not only that if left this way It can kill your heating element.
There are some thermal fuses located near the heating element, on the outside of the heating element housing, or some of them have the fuses on the blower housing. Check the element by ohming it out with a meter, if open, replace element. The dryer needs to have an un-obstructed air exhaust shorter then 15 feet from the dryer to vent properly when drying clothes.
Note: Normal drying time for a dryer
is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct,
is not clogged.
Unless regular maintenance is performed, chances are there is a lot
of lint accumulated inside the dryer. This might affect the drying
time and could be a fire hazard. Make sure to have your dryer
cleaned regularly. Because this might involve taking most of the
dryer apart, it is recommended to have a qualified appliance
repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one
of them breaks down, it might affect the dryer's performance.
Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case
it would still work but will take longer time to dry the clothes.
Replace the element if found defective.
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
