Question about LG RU-52SZ61D 52" TV
TV Won't Power On
When turning on the TV all I get is a flashing red light lasting about 10 seconds before I hear a click, another 15 seconds of red light flashing and then a click to shut everything off. It appears I'm not the only one with this problem. Someone else has had good luck with a circuit board replacement. I'll inquire at a couple of repair shops and determine if this is a solution to this problem.
It is not the circuit board, it is the lamp that needs to be be replaced all is well!
dlplampxpress.com
Code Item Qty Price Total 4930V00301 LG 4930V00301 Television Replacement Lamp
1 $139.00 $139.00 Sub Total: $139.00 Tax: $0.00 Shipping: $29.99 Grand Total: $168.99
Posted on Aug 26, 2008
Problem with Sony Grand Wega TV
This could be due to bad capacitors in the sweep supply, a bad High Voltage block, a bad regulator.
Jul 06, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
PN50B550T2FXZA won't power up
The continous red light merely means power is getting to your TV. From your description, it is likely the internal power supply has failed
Dec 31, 2012 | Samsung Televison & Video
Sony Wega 60" TV lamp light
Nope. It appears that you now have a main power supply issue since the set is dead.
Jun 23, 2017 | Sony Grand WEGA KDF-60XS955 60" Rear...
Plud the tv in and a click sound is heard like the tv is turning on but in 10 or 15 seconds green light goes off and a red light starts to flash. It flashes 4 times per cycle.
You may have the bad capacitor issue others have had in the power supply. Google your model number and the words "replace capacitors" for the solution. There is also a Youtube video. Also, check the fuses.
Sep 13, 2010 | Philips 50PF9631D 50 in. HD-Ready Plasma...
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
TV wont turn on
The main power supply is failing or it is shutting down because of a fault on the output side of it and it is trying to protect itself from overload which can cause a fire. Contact Zenith customer service and describe the problem, particularly the flashing LED which may be giving you an error code.
Sep 04, 2009 | Zenith E44W46LCD 44" Rear Projection...
Turning on problem with Panasonic Viva PT-43LC14
Sounds as you have a bad ballest. The ballest is the power supply that turns your lamp on. You can check your lamp by removing it and it should be clear and no broken pieces of glass. With the lamp removed install the cover and turn it on you should hear no noise and when the power light turns red you should see a LAMP red led blink every 5 seconds. If no noise then the lamp is bad. If you do hear noise you have a bad ballist. Hope this helps. Frank
Sep 05, 2007 | Panasonic PT-43LC14 43" Rear Projection...
Please Help
call a tech your tv needs to to be repaired the problem is in the power supply and related circuit.good luck.
Apr 07, 2007 | Sony KV-27FV16 TV
LG RU-52SZ61D 52" TV Logo
398 people viewed this question
