Question about Sony Handycam DCR-TRV8 Mini DV Digital Camcorder
Replacing Internal Battery
My date and time won't save anymore. How do you find and change the internal battery?
    New Friend:
Replacing Internal Battery - 0536ac96-96ab-4207-81d1-8c680dcfcbb5.jpgd8946833-3beb-4b20-af86-e7aacfb6f1f6.jpgWORD OF CAUTION;
There are many delicate parts and ribbon cables to be disconnected. This is not
a job to be attempted by anyone inexperienced in working with delicate and
static sensitive electronics. I take no responsibility for damage you may cause
in attempting this repair. If in any doubt whatsoever, TAKE THE CAMERA TO A
PROFESSIONAL FOR REPAIR.
I recently purchased a Sony PD100 camera from Ebay.
Generally it was in very good condition but it became apparent that the Camera
settings were lost whenever the main battery was removed. The most likely culprit was assumed to be the
coin backup battery.
With no obvious easy access to the coin battery I downloaded
the manual which was of little help other than "Take it to a Sony repair
facility". I am an experienced electronics engineer of 40 years. Nevertheless, it
was with some apprehension, I decided to bite the bullet and dive in. My
findings are as follows;
The data memory coin battery is located inside the camera on
the hidden side of PCB CK-80. This PCB is located on the inside of the casing
on the LCD panel side of the camera. The battery is a Panasonic VL2020 (BT7200)
rechargeable which is soldered to the PCB. There are several variations to the
VL2020, vertical mount, horizontal mount, rechargeable and non rechargeable,
none I could find had a reference BT7200. The best match seemed to me to be Panasonic
VL2020 HFE Lithium Vanadium rechargeable.
To access the CK-80 PCB, the rear main battery mount plate
and the top cover with the view finder have to be removed before the LCD side
of the camera can be removed. Take care not to put strain on the ribbon cables
and harnesses as you dismantle each assembly. (Reassembly of these cables is
also very tricky).
NOTE; There are many screws to remove, some are similar but
there are some that differ. I find it useful to keep the screws for each panel
or subassembly in different containers so as to avoid loss and to aid
reassembly. Make notes and use digital pictures as an aid to ensuring all
screws are installed and cable locations are not overlooked when reassembly.
There's nothing worse than finding screws left over after assembly with no clue
where they came from!
A twist in the tail.... Once I had access to the coin battery
I checked it with a DVM and found it was ok? On further inspection, I found
evidence of a little water ingress via the reset button and the switch and
surrounding area on the PCB was covered in corrosion. The DVM showed this
corrosion was leaking current across the contacts, effectively shorting the
reset button causing a permanent reset. I was able to clean the PCB and as I
had the new battery anyway, it would have been silly not to replace it while
the camera was dismantled. After the camera was reassembled (no screws left
over), The camera was fully tested and it now functions 100% correctly.
Once again, I would strongly suggest that anyone thinking of
taking this job on be certain of your ability. I take no responsibility for any
damage you might do to your camera.
Posted on Oct 08, 2013
  • K Harvey Oct 09, 2013
    One thing I forgot to mention. When you replace the coin battery, take the plastic insulator disc (just peels off) from the old battery and put it on the new battery to keep it away from the the pcb tracks.
    President:
  • 4,402 Answers
I would guess it be on the bottom where the tripod connect to the unit or in the back where the battery connects to the unit.
Posted on Feb 11, 2008
  • a126 Dec 23, 2010
    This camcorder doesn't have a clock battery, it uses the main li-on cell battery on the back
Every time I turn on camera it ask to set date,
The Time/Date battery is a small round lithium battery the size of a dime in the battery compartment. You can get the numbers off it and buy one at Walmart or Ebay.
Instructions for replacing it:
http://www.manualslib.com/manual/275745/Canon-Powershot-Sx10-Is.html?page=267
Jun 06, 2014 | Canon PowerShot SX10 IS Digital Camera
Unable to save date & time in lenovo g560 laptop
Sounds like your bios battery is on its last leg. The battery saves both the date and time... kind of like an "internal clock" if you will.
Jan 26, 2014 | Lenovo Computers & Internet
My canon A 400 does not save time.
When you say "the 2 batteries" are you including the date battery? See the "Replacing the Date Battery" section beginning on page 120 of this manual.
Jan 22, 2013 | Canon PowerShot A400 Digital Camera
Date and time won't stay set
Had the same problem. The problem is a small button cell that needs to be replaced. From Canon's support page:
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a510?CMD=MIXED_SEARCH&mName=PowerShot+A510&mType=PowerShot+A+Series&pageKeyCode=ekbresults&searchString=date+and+time+wont+stay&BASIC_SEARCH_CURRENT_TOPIC_ID=1236&BASIC_SEARCH_CURRENT_TOPIC_TYPE=0&RESULTS=RELEVANCE&RELEVANCE_START=1&RELEVANCE_COUNT=25&CONFIGURATION=1011&PARTITION_ID=1&TIMEZONE_OFFSET=null&USERTYPE=1&isSecure=false
Jul 13, 2012 | Canon PowerShot A510 Digital Camera
Need to set date and time at each starting. have changed 1220 battery what could be the reason
It sounds like you or the camera is not saving the settings. Refer to your manual for a step-by-step setting of the time. You're probably just not hitting some "save" key.
Mar 14, 2010 | Canon PowerShot A520 Digital Camera
New daylight savings schedule
(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.
Apr 06, 2009 | Emerson Smartset Clock Radio
Can my alarm clock be changed to automatically change for the new day light savings times? I have one clock and I bought one just like mine for my mother.
(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.
Apr 05, 2009 | Emerson Smartset Clock Radio
When battery is changed date and image size need resetting
Internal battery or capacitor may be bad and not holding charge to keep settings.
Oct 20, 2008 | Fuji FinePix F700 Digital Camera
INSTRUCTION MANUAL PDF FORMAT
The Manual is on the Disk that came with the camera.
However this wont tell how to change the internal 'clock battery'
This is a workshop job and will be quite expensive I would guess
Dec 10, 2007 | Fuji FinePix S5000 Digital Camera
Sony Handycam DCR-TRV8 Mini DV Digital Camcorder Logo
530 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
