Question about RCA 27V520T 27" TV
Tv not working
TV will not come on, when I unplug it and plug it back in the red light comes on but not the tv. tv won't come on.
  • sinky25 Feb 14, 2008
    thanks I am pretty sure you are correct, I have some experience on electronics but after the hurricane ( Katrina) I have not done anything but try to regroup the other part of my life. I really really appreciate you getting back with me and you take care.
  • jfkuk Oct 01, 2008
    I have the exact same problem, is there really no other possible solution/cause to this problem?
    thanks
  • 4,102 Answers
Hi the problem you are having is going to be one of the most common problems with that type of telly the problem is going to be the flyback transformer needs replacing and also the transistor neads replacing its the one located nearest to the flyback transformer and it will be on a heatsink.
If you are unsure what im telling you then you shouldnt risk the repair yourself as the telly has power stored in it even when its unlpugged it might not kill you but you will get a nasty shock as the voltage is amplified inside the telly so is greater than 240v so dont mess with it unless you are sure what you are doing.
If you are doing the repair yourself then you need to get the schematics so as you can get the test points that you can test using multimeter and osciloscope this telling you whats exactly wrong as a resistor or two could have blown when the transistor failed also the schematics will give you part numbers.
The transistor and any resistors are easy to replace but you nedd to protect the new ones from heat damage when soldering the new ones in you need to dispurse the heat using clips or something similar.
Now the difficult bit is unsoldering the flyback transformer this carrys high volts of electric and will give nasty shock if you dont dispurse the electric charge first you need to short across one of the caps to earth but you need to know the right one.
to remove flyback it regiures alot of unsoldering and resoldering possibly causing damage to the new one during soldering is easily done.
If you are going to get someone else to do the work like repair shop your looking at about £45 uk or $80 to $90 us so you need to think is it worth it let me know if you need further assistance ok
Posted on Feb 11, 2008
  • paul proctor Feb 15, 2008
    No worrys mate good luck with all you do if you need any further help just let me know ok
Plasma TV-power light does not come on
have you tried a completely different wall socket altogther/
Mar 03, 2008 | Samsung HP-S5053 Television
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
My panasonic th-50px60u television turned itself off last night and won't turn on makes clicking noise when unplugged and plugged back in but then nothing red light flashes
Tries tv unplug,replug it back like about an hour later for the tv to do it resetting itself back to the factory setting,tv might work again.If not still same problems.The tv 90-95% it is the board that call the tv power supply board is having a problems.That the board where the tv power a/c cord plug into it.U have all tools and know basic electronic and also can do basic soldering works too?Yes,take the tv aparts,check the tv power supply board carefully for dying and soon to be dead capacitors components parts.These capacitors components parts are alway bulges up or puffing up onto it tops.These dying and soon to be dead capacitors components parts are bulges or puffing ups on to it tops must have to be replaced will solved ur tv power unstable and flashing red light.Or try website like Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Jul 29, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
My Sony bravia kdl55hx800 lcd 3d tv won't turn on
try unplugging your t.v for a few minutes, then plug it back in. if it continues check your owners manual or google your issue. this might be the red flash of death. hopefully unplugging it works. good luck!
May 18, 2011 | Sony Televison & Video
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Flasing red light where the on light is
I have a philips pf50 9630a/37 tv may come on or it may not unplug it and take a chance then comes the 6 steady red flashes followed by 3 rapid red flashes the screen had been completely replaced by philips a year and a half ago
Mar 22, 2009 | Philips 50PF7321D 50 in. Plasma HDTV
TV will not Turn On.
same thing,tv won,t come on,unplug the tv, nothing at all,just yesterday my tv was fine, this is the first time this has ever happen
Mar 13, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
Toshiba TN55X81 Wont turn on but I hear clicking
Pull the three connectors to the yokes on the convergence board. If the set powers up, it's a good chance the STK392-110's need to be replaced. I fixed one today, and it has been running for 6 hours now.
-Dan
Jun 15, 2008 | Toshiba TN55X81 55" Rear Projection...
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
