Question about Samsung TX-R3080WH 30" TV
No picture Turn TV on and nothing happens. The power LED next to the power on button flashes. Is this power supply, picture tube?
  • steffensenja Nov 26, 2008
    TV turned off on it's own, when I try to turn it back on the standby light flashes-nothing happens.
    Genius:
  • 1,694 Answers
Bad solder connects....needs chassis pull,careful soldering..
not the picture tube.....................T.
Posted on Apr 19, 2008
When i push the power button nothing happens, I replaced the big computer board in middle of tv but didn't help, what can i do next
Most likely needed the Power Board.
If you search you tube with you eggzact model you might find people showing you how to fix it without replacing the board. (any good at Soldering?)
May 15, 2014 | Sharp AQUOS Quattron 60 Class LED 1080p...
AOC L32W961 No picture during initial setup problem I just bought this TV today. When I turn it on, the light turns blue, the screen says please wait for about two seconds, then the screen goes black, and...
If this is an LED set I'd look at a backlight error, some lamps in the panel are bad and the power supply is shutting down the LED supply voltage because of over current or under voltage.
Dec 24, 2017 | AOC L32W961 32 in. TV
TV: Sanyo 21 inch tube (about 10 years old) When TV powered on. When I try to manually or using remote bring picture on (i.e. by prg up or down), the power on indicator light starts flashing and nothing...
You have a power supply problem.
The microprocessor has its own supply and is not receiving a "hand shake" from the line output stage that in turn is not receiving and power from the power supply.
The chopper transistor will possibly be short circuit taking the feed resistor with it.
Check for dry joints everywhere and MAKE CERTAIN THE HT CAPACITOR HAS DISCHARGED!!!!!
Hope this helps.
Oct 30, 2010 | Sanyo DS31520 31" TV
TV will not come on
The flashing LED may be telling you the source of the problem; note the relative spacing of the flashes and the number of times it flashes before staying off. The set is trying to tell you where it is sick but I suspect it is related to the power supply; the most common failure point of most modern sets. If you post back here as a 'comment' you won't have to repeat your symptoms.
Oct 01, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Kv-32s120 standby LED blinking no sound or picture
How many times does the timer light flash between pauses?
Sep 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hitachi 60UX58B will not turn on
I think there could have been a power surge... ask the repairman if the power supply is blown. :)
Jun 18, 2008 | Hitachi 60UX58B 60" Rear Projection...
View timer only lights
TV WILL NOT NOT TURN ON RED VIEW TIMER LIGHT FLASHES AND THEN I CAN'T TURN OFF TV
Mar 29, 2008 | Sharp 61RWP4H 61" Rear Projection...
Philips 29PT8419-79R
the problem in power supply. if its output is ok than you will have to check horizontal section.
Sep 15, 2007 | Philips 27PT8420 27" TV
Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Jul 18, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Samsung TX-R3080WH 30" TV Logo
161 people viewed this question
Jerry Greenberg
Jerry Greenberg
