Question about Cyberhome CH-DVD 300 DVD Player
No picture, but can hear sound
Good afternoon,
At your convenience could you please tell me of some items/things I can check on my DVD to make it work? I purchased a Cyberhome Mini DVD Player with Progressive Scan (CH-DVD 300) around 06/2006. I still have the receipt. For the past six or seven months it has not been showing a picture. I can hear the sound fine but there is no picture. It is not the TV because every other channel shows well as it has always done. I took the DVD Player to the Walmart Customer Service department where I purchased it and they suggested I contact the manufacturer. Please make some suggestions as to how I can fix this issue. If you need me to give you the model and serial numbers please let me know.
Thanks and have a good day.
Keith T. Grimes Sr.
  • 84 Answers
Check the cable on the dvd and tv be sure its properly connected or try using a different cable. also if it has an s-video out use a cable for that and connect it to the video in socket of your tv. if it didnt work there is an internal issue on your player.
hope this works.
Posted on Feb 11, 2008
    President:
  • 4,402 Answers
Hold down the stop button for 5 sec on your dvd player not the one on the remote control
Check your connections. Make sure they are hooked up correctly(ie yellow to yellow. Check both the connectoins on the dvd player and the tv.
Frigidaire fahe4044mwo shakes in spin cycle
Good Afternoon Rob,
I understand your Frigidaire washer, model# FAHE4044mw0, shakes in the spin cycle, even after making sure your appliance is leveled. I also see that this occurs with small loads. Please make sure that your load is evenly distributed. If not, stop your washer and redistribute the load. Also make sure that the load is not too small. Try adding 1 or 2 similar items to even out the load. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire Washing Machines
Fridgidaire front-loading washing machine model # LTF2140ES0 will not spin
Good Afternoon Friend,
I understand that your Frigidaire washer, model# LTF2140ES0, will not spin. To try and resolve your washer not spinning, please try the following:
    1)Check your washer door and make sure it is completely closed.
    2)Check your dispenser drawer and make sure it is completely closed.
    3)Your load might be too small. Add 1 or 2 similar items to help balance the load.
    If the above does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 20, 2014 | Frigidaire Washing Machines
A loud airplane like sound is coming from the ice maker area. it goes away and comes back later
I understand that you are hearing a loud airplane sound, intermittently coming from the ice maker, on your Frigidaire refrigerator, model# FRS3R5EMB. You will hear a buzzing sound as the water valve opens to fill the ice maker during each cycle. I suggest resetting your refrigerator, by either unplugging it or shutting the power of at your home's circuit breaker, for 3-5 minutes. Restore power and try getting ice out of the dispenser. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 18, 2014 | Frigidaire FRS3R5EMB Side by Side...
How i get a motor for my dvd player
To tell you the truth, unless you have a high end unit it would be cheaper to just pick up a Sony DVD player at Walmart for $20, they have good picture and sound. But if you do have a high end you will have to go to the website for the manufacturer and type in what the exact model is and order the part which can range anywhere for $5 to $50. Like I said though it would probably be cheaper and more convenient to pick up a new one. Hope this helps:)
Sep 20, 2012 | Samsung DVD-V4600 DVD Player/VCR
Samsung DVD recorder
check your connection at the back. same thing happen to me. make sure the color coded cable matches.
Dec 22, 2007 | Samsung DVDR120 DVD Recorder
Black screen- cannot view pictures, can hear sound
ok do one thing,connoet rca video pin in component socket.. so that you can see bblack n white picture.
Aug 06, 2007 | Philips DVD 622 DVD Player
LGDVT418
i have the problem resolved got this answer from lg :
We are delighted to hear from you as our Valued Customer. We regret the trouble you have experienced with this product. Check the CENTER SPEAKER for operation. This single speaker carries the vocals for DVD discs, but is not uesd for TV and CD AUDIO. Check the wiring on this speaker to make sure that the contact points on the DVD player are touching the wire, and not the rubber insulation on the wire. If you have other questions or concerns, please do not hesitate to contact us again either via email, or by calling our customer service division at 800-243-0000 at your convenience. Neil E Electronic Correspondence Executive (ECE) LG Electronics USA 800-243-0000
Feb 07, 2007 | LGDVT418 System
Cyberhome CH-DVD 300 DVD Player Logo
89 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
