A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so,
please see this link for further info and a simple fix that may help.
tv has shadows in yellow in blue. Yellow arch on the bottom. Blue at the top. Comcast tv guide when called upon has a shadow of itself above the orginal. Baseball thrown has a yellow or blue shadow depending on where it is at on tv screen.
tv has yellowis and bluish tones. Yellow resides on the lower half. Blue on the top. Everything has a shadow no matter how dark the picture.
TRIED: Pushing on the cables to make sure they are in good. Checked the convergence tried different things with that setting. Menu and picture function did nothing for me either.
I've heard of bulbs going. Is this possibly one of those things. If thats the case am I better off buying a new one.
