Question about HP Pavilion zv6005us Notebook
ZV5370US Optical drive no longer works
The DVD stoped working after trying to burn a DVD. I can hear the head move when I insert a disk but I can't hear the drive spin up. What are the chances the drive just died and there are no other issues that would cause this problem?
Thanks
Art
art.atkinson@gmail.com
  • artatkinson Feb 12, 2008
    Thanks for the reply SirHanz,
    I have tried several different disk with the same results, no spinup. I suspect the cost of labor to troubleshoot the drive would approach the cost of a replacement drive. So the gamble is to just buy a drive and hope there are no other issues, or sent the laptop to a service center.
    art
  • 145 Answers
Those chances are pretty high, although I would try testing with different discs, and types of discs. In example dvds, cd's, I don't recomend CD or DVD R RW discs though, they are generally harder for the drive to read. Also with the cost of replacement laptop parts you may consider trying to have it serviced before accepting defeat and replacing the unit.
Posted on Feb 11, 2008
It will not play Verbatim DVD-R disc that I burnt on my computer.
If it can read any other disk, you should burn your disk again because burning process was incorrect. your computer can't recognize the disk. In this case, probably you can't do anything, no way to try to read a bad disk if computer can't even "see" it.
By the way, you should test to read the disk on some other computer.
If happens with ALL your disks, your optical player is defective.
Again test reading with other computer if record was made correctly
As for your device, you should check if worth to repair and decide if repair or replace it.
How to Replace DVD CD Drive in Computer Tower
How To Install Computer CD DVD or Bluray ROM Drive Ep 7
Replace Laptop DVD CD Optical Drive Complete Tutorial
How To Replace the Optical Drive HP Pavilion DV6 Laptop HD
Sep 03, 2015 | Televison & Video
ITunes will not burn disk
A few thoughts have you tried to burn the disk using another application other than itunes. Have you tried a different disk or a different brand of disk? If the problem still exists it would rule out problems with the application and the disks. However it would probably mean that the disk drive is not working properly, you could try using a dvd head cleaner, but mac DVD drives do not have a great history with regards reliability. If it is still under warranty arrange an appointment at the genius bar at the local apple store and you will be able to get it replaced. The only other thing to do would be to purchase an external dvd drive, make sure it is mac compatible. Hope this helps.
Feb 23, 2012 | Apple Macbook Computers & Internet
No picture when disc inserted in DVD DVD turns on
Please check the connections , check the leads from the DVD to the TV, use the line out from DVD to the line in the TV using the video and audio inputs. If this wont work then in most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Jul 14, 2011 | Philips DVDR3320 DVD Recorder/VCR
When i put a dvd in you can hear the dish spin then it says to insert disk,when the disk is in there.
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
Apr 16, 2011 | Philips DCP750
Now, when I insert a disc, the player just indicates "loading" and will not play the disc. Just prior to this, it would play the movie part way then "freeze". I couldn't rewind or...
Please try to put in an ordinary audio CD track and see if this is detected. If yes the optical is working, if not there is no laser scanning and the possibility of the head being faulty is high.
Certain cleaner disks may not work but the best is to cleaning manually the laser head eye with a cotton bud, very gently and without pressing of the lens eye.
If there is still no result then watch the CD if it spins or tries to spin. If the head unit moves up or down to focus or in and out of the drive, if so the board seems to work correctly and the possibility that the optical head unit is the suspected fault.
Jan 05, 2011 | Curtis DVD-7600 DVD Player/VCR
My dvd player stalls when i insert dvd (series) discs
Please try to put in an ordinary audio CD track and see if this is detected. If yes the optical is working , if not there is no laser scanning and the possibility of the head being faulty is high.
Now certain cleaner disks are not read and so will not be tracked. hence the rejection but the best is for cleaning manually the laser head eye with a cotton bud very softly and without any pressing of the lens eye.
If there is still no result then watch the CD if it spins or tries to spin. If the head unit moves up or down to focus or in and out of the drive , if so the board seems to work correctly and the possibility of the optical head being the suspected fault is closer.
Finally try to see if the set records on a DVD with a given signal source. If not the fault is confirmed.
But if any of the above seems otherwise we must recheck with possibilities of the processor board
Sep 28, 2010 | Computers & Internet
My DVD RW not reading any disk when i insert the disk into drive. so plz guide me.
there is no other way but to clean the optical head .
Try with a recommended brand of the DVD, origianl version, If the message still comes thus, then it is possible that the optical head unit is faulty.
Confirm the unit with the service dealer for cost estimation/warranty before you decide.
Aug 28, 2010 | Computers & Internet
My cd/dvd drives display "insert disk in drive E" even when a disk is inserted
Hi, two things you can try.
1 Use a different burning program,there are many free ones on the web, I use Ashampoo Burning Studio 6 Free .If that does not work with your disks 2 Try a different brand of disk. Hope this helps you.
Regards Bill
May 11, 2010 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
When i try to copy dvd it keeps telling me to insert blank disc even though one is in there i can burn cds but not dvd it tells me to put in writeable disk and ive put in dvdr-w and dvd-r and still it...
Go to the device manager to insure your optical drive is in fact a DVD/RW. You should also be able to tell by looking at the front of the drive and see what it says. If it says CD Writable or DVD Rom, you cannot do it. Kind of sounds like you have a CD/RW-DVD Rom combination drive, which does not allow the burning of DVD's.
Let me know, OK.
Mar 15, 2009 | Dell Inspiron 1501 Notebook
Does not recognize/play DVD - shows "NO DISK"
If you are good at repairs.dismantle the Disk drive unit carefully from the main carriage and if the Optical lens reading unit has got a drive P C B ,then desolder the PCB so that you have only the CD mechanism on your table,with a Digital Multimeter check the Ohmic values of both the Spindle motor and Sled motor. the resistance should read between 4.5 ohms and 8ohms any value beyond this means that the drive signal voltage is not enough to move /rotate the disc and optical-pickup in syncronisation.you can get the drive-motors replaced,or replace the CDM assly available off the shelf.
this should solve the problem.hundreds SONY DVD players are running with this remedy.
Nov 29, 2008 | Sony DAV-C900 System
HP Pavilion zv6005us Notebook Logo
70 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
