Question about Dishwashers
Hotpoint dishwasher will not fill
Makes right noises except for running water sound. have checked water inlet filter and found it clear. water gets through to this point but no further,
    President:
  • 1,314 Answers
It could be a timer problem bad water valve but the first thing id check is the safety switch that's the switch that the float in the tub sits on and check to see if the float in the tub is hung up
Posted on Feb 11, 2008
Miele Novotronic 500, 10 years old, noisy filling, no error light, inlet filters clean. Any suggestions please?
Hi dear,
As I know it's a indication on inlet valves going to fail. I hope that helps. Thanks.
Jan 21, 2016 | Miele Washing Machines
Kenmore 17621 model--wife says it's making all the right noises,but no water entering.removed bottom panel-no filter visible.obstruction in water supply line is my guess.
Open the door and look for the water level float in the bottom of the dishwasher.
Make sure there is nothing stuck under the float holding it in the up position.
Wiggle the float up and down to make sure it can move freely and then run the dishwasher again to see if it fills with water.
If the float is not stuck up then chances are you will need to replace the water inlet valve.
If you know how to use a volt meter you could check to see if voltage is at the valve during the fill cycle. If there is voltage to the valve but you are not getting any water then you know the water inlet valve is bad for sure.
I find that 90% of the time I need to replace the water valve on dishwasher that no longer fill with water and the other 10% of the time I find the water float is stuck.
Aug 07, 2011 | Kenmore Dishwashers
Machine is not filling and making a hissing noise
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Feb 13, 2011 | Bosch 24 in. SHX46A05 Stainless Steel...
Dishwasher is not filling up with water
Hi
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter hen you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Oct 25, 2010 | Hotpoint Dishwashers
My Blanco dishwasher does not fill with water but makes noises like it's working
Check water inlet. Add water straight into the chamber manually 10 liters or as required,from the front . Close the door and run the machine. If air is trapped it will get cleared! however check free flow of water in the inlet rubber hose.Check the soleinoid valve water inlet for functioning. If the solenoid valve is not opening, then also this water flow problem into the machine will be.
May 18, 2010 | Dishwashers
Water fill problem on Hotpoint Dish Washer Deluxe Model DF 31
Pl check the small filter fitted near the water inlet hose. Probably you may have to pull this filter as this is housed in the threaded pipe attached to the body.
Remove the hose from the machine and try flushing. see whether you get sufficinet pressure from over-head tank!
Clean the filter with tooth brush or reverse clean. Do no for get to fit rubber washer.
Mar 30, 2010 | Hotpoint 24 in. DF55 Free-standing...
I have an FDF780 dishwasher that wont spray water
Sounds like wash pump is weak or siezed.
Sep 28, 2009 | Dishwashers
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
LG Dishwasher (LDS5811) - low water level
1E= Inlet Error
Condition>>>
Not reached to the normal
water level in spite
of 10 min. water supply
The Water Supply Tap is closed.
The Water Supply is shut off.
The Inlet Hose is kinked.
The Water Pressure is very low.
(below 10 psi)
Inlet Valve is OK?
The filter of Inlet Valve is clogged
by impure water.
The Hall sensor is OK?
The Impeller of Air Guide is bound
Solutions:
Take action on Water Supply
device.
Measure the electric resistance of
Inlet Valve. (950-1300 )
Clean the filter of Inlet Valve.
Check the frequency of Inlet Water
by the Test Mode.
Replace the Air Braker
Aug 20, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Won't start
It sounds like you have a food blockage or some blockage between where the water fills up and where it goes into the pump you need to take out the water wand (the rotating thing with water coming out) only the bottom one. You need to unscrew the water wand and make sure nothing is blocking in there.
If not then check your filter which should be next to the water wand remove it and then clean it and make sure nothing in in there to block water getting through.
If you have any questions please dont hesitate to ask
May 27, 2008 | Hotpoint 24 in. HDA1000Z Built-in...
Dishwashers Logo
89 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
