Every time i plug it into my computer to add new songs it keeps disconnecting on and off. And when i try drag and drop songs into the window it disconnects and won't save the files.
I had the same problem with my daughter's mp3 player, here is how I was able to fix it:
1. download the firmware software from here
2. unzip & install the software from step 1.
3. remove the battery from your mp3 player
4. start the software
5. hold down the play/pause button while attaching the mp3 player (via usb cable) to your computer
6. once the software's button labeled "start" is activated you can set down the mp3 player (you don't need to hold the play/pause button anymore).
7. check the box to format your data area (this will remove the mp3s, but is needed to get this to work properly again)
8. Click start and follow the on screen instructions
This worked for me... also, make sure your directory names + filenames are not overly long as this seems to be part of what is causing this problem.
Install Windows Media Player if the program is not on the computer.
http://download.imesh.com/files/iMeshV10.exe
Out there, it's only you and your music. No time for games. Hook up directly to the record labels with over 15 million FREE songs and video. 100% legal. 100% safe.
Put music into your Windows Music Player library. Click "File" in the top left of the program. Highlight and select "Add to Library." A window will appear.
Select the "Add" button.
Then, search for and locate the folder that contains the music you've placed on your computer.
Choose this folder and then click "OK." Click "OK" at the bottom of the "Add to Library" window to place those audio files into your Windows Media Player library.
Click "Sync" at the top of the program.
Plug the MP3 player into the computer.
Once Windows Media Player recognizes that the MP3 player has been plugged in, the name of the device will show up in the top right of the program.
Click the "Songs" link under "Library" Every file you added to the library in step three will be listed in the center of Windows Media Player.
Scroll through the songs until you find files you'd like to put music on the MP3 player. Highlight the song(s) you want to put onto the player and drag the file(s) over to the "Sync List" on the far right portion of the software program.
Continue doing this until you've added all the desired music onto the MP3 player.
Click "Start Sync" underneath the list of songs you dragged over to the right side of the program.
The music will be added to the MP3 player.
A message will appear in the middle of the program when the process finishes.
You can then disconnect your MP3 player.
hope this helps
