Question about Handspring Treo 300 Handheld
Battery Charge Hey Fixya! My Treo 300 phone won't charge using the sync cable (sync works perfectly). Should I take the phone to Sprint or buy a wall charger for treo? -DylanT
  • CodePackage Feb 11, 2008
    Ok - I've heard you need to jingle the USB cradle around once its plugged in to the treo to get it to charge. Should I do this? No I don't have a warranty anymore.
  • 84 Answers
If it still has warranty, yes take it to sprint if does not try get a charger but before you buy it check if it will work on your phone.
Posted on Feb 11, 2008
Iphone won't charge if on
Hello My Dear::::::\
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 12, 2013 | Apple iPhone 3GS Black (16 GB)
My cell phone wont hold a charge
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 28, 2011 | Sprint LG Rumor Touch Phone cover by...
I dont have the disc from my old phone, how do I download pictures from it??
You will need to download and install the following Palm software to get access to all your content. you can then download your pictures from it.
http://kb.palm.com/wps/portal/kb/common/article/12317_en.html
Thumbs Up!!
May 06, 2011 | Sprint palm treo 650 755P USB Outlook Sync...
I have a palm treo that isn't booting.
I believe this means your battery is no longer sustaining a charge enough to power your phone. I would recommend replacing the battery. You should be able to buy a new or used battery from your phone vendor or authorized reseller.
Good Luck,
Jesse
Jan 13, 2010 | Palm Treo 750v Smartphone
I left my power cord at work
A USB port supplies 5v at 1amp
If you only draw 500ma off there is a chance that the voltage will go up to 6v
Not a killer if it wants 5v but you will cook the phone if it only needs 3.7v
Some phones will only accept 3.7v (Some Nokia units)
Look at the phone battery and it will tell you what it needs
May 24, 2009 | Palm Treo 500 Centro
Palm centro will not power up
One word: RIDICULOUS. My Centro randomly Hot Synced one night, and never worked again. I went to a Sprint tech 5 times, literally. I had the insurance coverage and they order me a new phone. When I picked up my new phone, the tech turned it on in front of me. I go home, charge it up and NOTHING. Went back down to Sprint tech. Sprint does not cover the battery of the phone, and they gave me my OLD battery with my new phone. The phone worked with the tech's battery though (?). They gave me a new battery, go home charge and...nothing happens again. Went back, they checked my charger, and everything looked fine, except they had no clue what was happening. I still have the phone that I can't sell because it has all my info in it.
In the end, I went to Verizon, and ate the $200 termination fee. I called Sprint and said fix my phone or eat the termination fee, and they gladly waived the term fee!! TRUE STORY. The grass is greener at Verizon. They help you save money on your plans, seriously! You may think this sounds like a Verizon commercial, but after 6 years with Sprint, I wish I made the move earlier, much earlier. Search the internet for loopholes on how to cancel your contract without paying! Good luck!!
Aug 15, 2008 | Palm Treo 500 Centro
New battery on used phone won't charge
The battery might be bad you can go and have someone check the battery at any electronic store with a voltage meter.
Apr 22, 2008 | Palm Treo 700w Smartphone
Palm treo 700 wx won't charge
Verizon 700wx:I had the same problem. With little or no movement, the phone would go from charging to not over and over. At home with it perfectly still it would charge maybe 1/4 in 6 hours. Same problem with 3 different chargers. With the battery out, I dipped a Q-tip in rubbing alcohol squeeze out excess and jammed it into the charging port on the phone. Put the battery back in and oh **** nothing. Took it back out and let it dry for a few minutes and were back in business. No more charging problems at all.
May be a little risky, but warranty was up and what did I have to lose. Anyway good luck!
Feb 16, 2008 | Palm Treo 650 Handheld
Battery indicator/charging defect
Do you have a Treo desktop charger/sync cradle where you can drop the battery into the charger?
Jun 14, 2007 | Palm Treo 650 Handheld
Handspring Treo 300 Handheld Logo
61 people viewed this question
Top Handspring Computers & Internet Experts
ray gallant
Are you a Handspring Computer and Internet Expert? Answer questions, earn points and help others
