Question about Samsung SGH-E900 Cellular Phone
How do i fix my phone
I can hardly see any thing on it, it all white and it not clear
  • jfitz93 Feb 24, 2008
    samsung s400i
    i have the same problem with my phone. screen is fine one minute the all white or writing upside down
    Sergeant:
  • 379 Answers
I think you have broke the ribben to the screen go to a phone shop and get it checked out
Posted on Feb 23, 2008
My samsung galaxy grand prime is freezing and very slow in operation. it have been hard reseted but is still persist. what should i do?
Clear up as much internal memory as you can. Put apps onto SD Card. Clear the miscellaneous files completely and clear all the cached data. That should do it.
Jun 07, 2016 | Samsung Galaxy Grand Prime G530H/DS...
Why Play Store Forever Loading ?
Try going to:
Settings > Apps Manager > PlayStore. From here tap Clear Cache and clear Data, reboot your phone.
if it still doesn't work, you could try to uninstall updates, same procedure as above.
Your last resource, in case nothing else works, is resetting your phone to factory settings. Every phone is different, so must search for it. Type "How to hard reset ZTE Score".
Jun 06, 2014 | ZTE Score
CLEAR SCREEN
When I open the mobile -slide it- the screen is clear -white-
Jan 08, 2010 | O2 Samsung SGH-E250 Cellular Phone
SCREEN TURNED WHITE AND CANNOT BE CHANGED
Let check it out what really happen. Does your son drop the phone accidentally? or done something undesirable things to it? Whatever the reason, the best thing to do is to take your phone into a cellphone repair shop. It will be handle by a qualified technician to do the task. It is clear that the phone got a serious problem that is why it does not show anything. Neither phone hardware or software problem it should taken to a repair shop. okay..:-)
Dec 18, 2009 | Motorola Mobility Rival A455 Cell Phone
Low free storage alert on my tmobile dash
you have to do a master reboot on the phone.. that will clear up the things that you cant erase... Hard reset:
1. Power off
2. Push both white dash keys and power up.
3. At T mobile screen it will change to black with writing and instructions.
4. Let go of soft keys and push send (follow directions on screen).
5. Formatted!
Jun 06, 2009 | Jabra T-Mobile Wing / Dash / SDA /...
My Samsung M520 slider screen goes white and freezes
yeah i also have a samsung m520, and its rececntly been turining white then back to normal. Its really annoying. I got it replaced last year with the warranty but now, about a year later, it turns white again. I went to the Sprint store and they said the cord that connects the screen and slider is either cut off or damaged. I like never drop my phone or in water, and its sucksss...
and i thought Samsung was reliable.
Feb 12, 2009 | Cell Phones
Apple iPhone Smartphone
telecharger and installer this program i phone PC Suite in this set
http://iphonefreakz.com/2008/08/20/iphone-pc-suite-compatible-with-firmware-20/
and pronsh your phone with one usb verifier if your phone
is connected in the programe
Click in system. Fix startup…..
Jan 23, 2009 | Apple iPhone Smartphone
Metro pcs motorola razr v3m blank screen
I had a friend who had a razor and it did the same thing, what she would do (and only sometimes this would work) is she would close it as fast and hard as she could and it would fix itself, but eventually it got bad enough to where she had to get a new phone...
Oct 13, 2008 | Motorola Mobility RAZR V3m Cellular Phone
White screen with red and blue lines
Try removing the battery for a few seconds and see if that clears up the issue.
If it does, be aware that it's most likely a temporary fix. You'll want to go through the phone and clear out some of the memory (saved text message, call log, and even pictures if there are a lot of them). You might want to consider stopping in at your carrier's local store and getting the software flashed as well.
May 07, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
White screen`
the white and black screen issue on the Razr V3xx can be a bad LCD. If the LCD is good then the issue is on the main board. The most common failure is broken contacts on FL6505 and FL6504. resoldering might hold up for a while but replacement is the best option.
the side view clearly shows the damage to the filter. this is only visible after the solder is removed.
hope this helps.
Oct 07, 2007 | Motorola Mobility RAZR V3
Samsung SGH-E900 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
