Question about Sherwood RD-6105 Receiver
Comes on and goes right back off
Comes on for five to 40 seconds and goes right back off
  • nettlerash Feb 11, 2008
    it is a model RD-7103, Don't how it posted it was a RD-6105
  • Anonymous May 03, 2008
    It sounds like I have the same problem. I have the RD-6105 and I heard it short out while I was fiddling around the back of it (may have shorted the speaker wires) Now when I turn it on it automatically turns itself off after about 3 to 5 seconds. Any idea how to fix this. There was one fuse inside that I could see but it appears not to be blown.
One of three things could be happening:
1. the most likely problem is that the impedance in the speakers is too high, causing a short
2. a faulty mechanical relay, there are two - 1 on the PSU and 1 on the main chip. the relay on the main chip may be faulty
3. there could be a problem with one or both of the main capacitors. the two caacitor responsible are huge and hard to miss you can order them from jay car pretty cheap!
Posted on May 03, 2009
Vizio tv repair picture blurs and darkens for five seconds and then goes normal for five seconds and continues this cycle. i changed the tcon board and no change.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Jul 29, 2015 | Vizio Razor M501D-A2R 50" LED Smart TV...
Igniter comes on and flame comes on. Igniter goes off and 40 seconds later, flame goes out. About 40 seconds later, igniter comes back on and then flame comes back on. About 40 seconds later, flame goes...
It sounds like the sensor that determines that a flame is present is not working. Find this sensor by looking for a device that is exposed to the flame and has wires going to it. Check this sensor and replace if necessary.
Sep 12, 2013 | Dryers
HP 1702 Monitor comes on but immediately goes off.
There are five capacitors on the power board which have dried out and need replacement. A reputable repair shop should be able to fix this for around $50.00 including labor.
Mar 23, 2009 | Computers & Internet
Fiering order on coil pack p38 40.l
As you look at the engine - Spark plugs first......on the left side of engine.......front to back.......2, 4, 6, 8 (even right),....2 goes to the left coil...top left.....4 goes to the right coil....top left......6 goes to the right coil...bottom left....8 goes to the left coil....bottom left....NOW....right side......front to back......1, 3, 5, 7 (odd left).....one goes to right coil....bottom right.....three goes to left coil....top right......five goes to left coil....bottom right....and seven goes to right coil....top right....hope it helps
Jan 28, 2009 | 1999 Land Rover Range Rover
No sound no picture, the stand by light blinks four times
If you have the above model, then the four blinks indicate a backlight failure. The back light inverter board might be defective or the voltage from the power supply (+24v) is low or missing.
Let me know if you require further assistance.
Dec 30, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Five second delay with pump
check the intake of the pump. It may be clogged with sludge or debris.
Oct 02, 2008 | Little Giant 10 Cia, 1/2 Hp, 83 Gpm...
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sony Bravia 40 inches has a defect
More then likely your power supply failed. If you do not hear a click from the relay during the power up cycle then your power supply failed.
Jul 29, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sherwood RD-6105 Receiver Logo
168 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
