Zenith rear projection 1997 z60283r8 (60")
I have power and sound no picture. I pulled the unit out of back of tv,smells burn't. nothing is lit up.
  • 8,617 Answers
Check around the flyback for burn holes or splits in its case. May also want to check the horizontal output and regulator transistors for being shorted.
Posted on Feb 12, 2008
I have a Zenith 54"
You have Bad Convergence ICs they are Big Black ICs and will have the part number on them ,example STK392-570 Mats Electronics has ICs 1-800-628-1118
Jul 03, 2011 | Zenith R49W36 49" Rear Projection HDTV
Zenith Projection Television R45W47
Ur tv the convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts are defective still have some life left,it will causes colors lines like RED,GREEN,BLUE misaligns,colors shadows,3D picture.When the 2 STK covergence ICS are totally dead it make this cricket noises and burning smell.The shop cost u $300-350 for parts and labors.
Jun 15, 2010 | Zenith R45W47 45" Rear Projection HDTV
Picture went out. sound works. smelled something burning
Replace Deflection/ power supply board,FBT flyback Transfomer will be on it.
Call Zenith Module Exchange 1-800-632-6637
Cheaper just to replace board.
May 02, 2010 | Zenith R60V26 60" Rear Projection...
Loud sound of air and screeching tv keeps powering down
Sounds like a CRT is arching internally. to confirm remove the covers to have a view of the picture tube necks- in adimly lit room you should see bue arching in one of the tubes. (there are three piture tube with glass necks)
Sep 14, 2009 | Zenith R56W36 56" Rear Projection...
"pop sound", picture out, burning smell...?
Usually, yes. A bulb that has audibly 'popped' will be apparently bad if you pull it out of the TV (shattered). Other times this is a lamp ballast board.
May 18, 2009 | Sony KP-53XBR45 53" Rear Projection...
Wont turn on smell burning
Can you remove the rear panel and check if the hissing is coming from the flyback? Which is a large transformer with a large red wire coming from the top of it? If so can post a link where you can get a replacement their not exspensive and their easy to replace. If its not coming from the flyback post a picture of where the hissing is coming from and I will identify the parts for you, But I feel its the flyback due to the hissing. respond to this same post so I have your correct model number when you reply.
Jun 25, 2008 | Zenith R57W46 57" Rear Projection...
Zenith R56W36 television
sounds like the flyback transformer is bad would need to change the supply module 6871VPM997D approx $175.00 or replacement of flyback T403 and part number 6174Z-6400B runs 49.27 but would require soldnering skills
Nov 20, 2007 | Zenith R56W36 56" Rear Projection...
TV suddenly blanked (power is not off)
It is probably a burning deflection yoke.I just fixed an identical model with the same condition,Jim
May 20, 2007 | Panasonic PT-51HX41 51" Rear Projection...
No picture or sound
If you had a burning smell, well the board is toast. These sets are made to replace the entire board at one time. Before installing the replacement module, the picture tube should be checked. A defective picture tube ( such as a G1 short) may cause a failure in the power supply section.
Sep 07, 2006 | Zenith C32V36 32" TV
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
