Question about Pioneer AVH-P6600DVD Car DVD Player
Flip out the unit will not close the face. how do I repair?
Possible the monitor motor is jammed or broken!
Posted on Mar 27, 2008
Unit face will not stay closed
Legacy does NOT sell any sort of repair parts and, therefore, there is no way to repair any problem with that unit. Sorry.
Jul 11, 2011 | Legacy LD63MU Car DVD Player
When I hit the 'open' button the face continues to cycle
ribbon tape sounds bad. it goes from the units main board to the detachabel faces rear mounting plate , u can inspect it for cracks , most of the time theyre visibel from looking under the unit while face is open
Oct 17, 2009 | Pioneer Car Audio & Video
The face will not light up when it is closed. No buttons work, either.
You may have a bad contact on the faceplate or on the main head unit. You can try cleaning the electrical contacts with a small amount of rubbing alcohol and a cotton swab. If this doesn't help, then you may need either piece serviced. Often times the solder joints on the PC boards inside the head unit or inside the face may need to be repaired. A local stereo shop can check for this or a local electronics repair can look for "cold solder joints"
Aug 10, 2008 | Clarion DRX-9675Z CD Player
Kenwood kdc-x869
Alot, of the radios have a common problem with the connection from the radio's detachable face. What happens is corrosion builds up on the connectors between the pin and the connector itself. Sometimes you can clean it off with a small file. Also, some KENWOODS with the motorized face are known to have a problem with the ribbon cable connecting the face plate to the main board. The last time I repaired one I called KENWOOD and aquired the cable for about 65 dollars, what the problem is, is the cable is wrapped around a plastic white spindel with a high tension spring and places alot of pressure on the cable from the wear and tear of the face opening and it will cause strange problems such as: turning on and off, some buttons working while others don't, and the display partially turning on and off.
Dec 15, 2007 | Kenwood eXcelon KDC-X879 CD Player
Dual XD7600 Head Unit Problems
Sounds like the flexible connector that connects to the drop-down front panel is bad, broken pattern lead.
Aug 07, 2007 | Dual XD7600 CD Player
Alpine head unit CDA-9855R
Yes, I'm sure Alpine will sell you another face but there is still the option of repairing the broken face at a good repair shop. Of course getting a new face is the easiest (read most expensive) way to get you going again.
Jun 08, 2007 | Alpine CDA-9855 CD Player
Unit powers down when motorized face opens
i also have had this unit for over four years. the exact same thing just happened to me yesterday. i was thinking maybe it is the motor that opens the face. has anyone found an exact solution for this problem yet?
Apr 11, 2007 | Pioneer DEH-P8500MP CD Player
Sony CDX M8800 Front Panel Problem
u need 2 replace the ribbon that goes to the panel to the unit.i had the same problem with mine then i went on to ebay and found the ribbon there (cdx-m8800 repair kit)hope this helps
Dec 17, 2006 | Sony CDX-M8800 CD Player
Kenwood KDC-715s problem.
the kenwoods with the motorized face platesdevelop one problem with time. the flexable ribbon cable between the main unit & the face plate. as the face open & closes, over time wares out the cable. problem consists of face plate not opening/closing, display missing & and/or some or all buttons not working. note these can also be intermittent problems. typically the part number is located on the cable itself on the side where it pluggs into the main board. since you have a service manual, you should verify it in the manual. good luck.
Dec 03, 2006 | Kenwood KDC-715S
Pioneer AVH-P6600DVD Car DVD Player Logo
48 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
