This range is flashing F-30. When I looked it up it said to check the RTD sensor resistance chart. If resistance doesn't match chart to replace the sensor probe. I am unsure how to check resistance but we replaced the probe and that did not fix the problem. Any ideas????
If you ohm the sensor probe, and it ohms good, check your schematics, you'll find a Thermal Circuit Breaker, actually two of them, in series with the probe. This is a resettable switch, and im not 100% sure what trips it, although im thinking its most likely a thermal overload switch, but i've noticed it can be tripped by accidentally applying to much pressure to the area the switch is located. The switch is located in the right area of the control panel, right behind the rear burner knob. You might look at this as it fixed our stove just fine without paying to replace the probe. You might check into what causes this however, as mine was tripped by pressue, not a fault.
Master_Tech Pls. send me the information on this at ([email protected]) Thx in advance.
Thank you. The info is great. I found the previous repair tickets, the first was as you metion the breaker, the second was the sensor probe. I will send you the results of this repair.
I found the service flash...On how to repair this ... plz post your email and i will send it to you on this problem?
Check your email
Gary, I have a Frigidaire PLES389ECH. After my wife was boiling a very large pot of water (canning) our oven control panel stopped working. The oven light swtill works. Based on the above comments I suspect the weght of the pot caused the thermal overload switch was tripped. How do I get at it?
[email protected]
[email protected]
Hello, My stove is flashing F30 as well when I try to turn on the broiler or turn to bake.
Before I call a service person what can I do to trouble shoot?
Thank you.
Debbie
[email protected]
My Frigidire model # PLES389ECH.Unit is displaying ER-30 when selecting one of the 'even cook' selections. I disconnected the AC for app. 2hrs for a possible 'reboot'. I reconnected AC, no change in the selections operation & I lost the clock function, can't set the time. The top burners function. The unit was repaired under warrenty approximately 1&1/2 year ago for a simulator malfunction. The tech replaced the thermisitor you previously mentioned. Could this by a repeat?
where can i find a diagram of the stove? i have the the same problem and want to try the switch reset but how do i get to it. thanks
my PLES389ECC series is displaying f 30 and will not let me bake? what do I do ?
I have a Frigidaire model PLES389ECH. My wife was baking zucchini bread and boiling a very large pot of water for canning. After this our control panel for the oven quit working. The oven light switch still works. I tried powering the stove off and on but no reset. I suspect the weight of the pot of water caused the thermal breaker switch to trip. Once I figure out how to get at the thermal circuit breaker I will try to reset it and cross my fingers. I will post here with results. A local repair man estimated it could cost over $400 to replace our control panel!
