Question about NetGear DG834G Router
Connection to ps3 drops in and out
Tried the router ip and when prompted i input no username and admin for the password but not bieng allowed to access port forwarding, i've got a DG834PN any ideas thanks.
  • mastoy Apr 30, 2008
    I have no problem connectng at home, but when I'm out and try to connect, my laptop recognises that there are routers in the area, but it does not allow me to connect. Or sometimes it may connect, but not allow me to connect to the internet. What can I do to connect?
    Problem Solver:
  • 18 Answers
GO to network settings...Check out Settings and Connection status list...make sure everything is enabled, wireless, and Automatic....reset your connection..and ur router....turn off the WEP ...security disable....
internet connection : Enabled
connection method : wireless
signal strenght: 100%
SSID : (name of your wireless router)
Security: i set NONE....no one really cares to hack ur PS3 ppl turn this off
Address settings : AUTOMATIC
Posted on Feb 20, 2008
Hmm
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 08, 2011 | Belkin (F5D8231-4) Wireless Router...
I just received a new modem from my cable company and now my router doesn't work. I tried resetting it and it still doesn't work. What do I do next
Sep 07, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Netgear router try to connect but saying validating identity wat can i do
Sep 07, 2011 | NetGear RangeMax WPN824 Router
After trying to connect my mac laptop to ethernet suddenlink had a failure at the same time. NOWI CAN NOT OPEN THE ROUTER OOR ANYTHING. jim FOUTTY
Sep 07, 2011 | Linksys WRT160N Wireless Router
New password wifi
Sep 07, 2011 | Encore 802.11G WIRELESS LAN ROUTER...
Lynsksy E1200 tried to reset. my passord and network name are of no assistance. After running software, router is not found. Tried using "admin" for both but nothing works. Please advise. ...
Sep 07, 2011 | Computers & Internet
How 2 put the password?
Sep 07, 2011 | SMC Barricade N Wireless Broadband Router...
I have a trendnet tew-625brp, i just opened it, i can connect to it perfectly by cable howeve i want to set it up wirelessly, when i go to 192.168.10.1, i type in admin for username and password, and it...
You must complete the setup with a wired connection. Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Emachines by acer/ana/unlock passwordto wifi connection,,,i cant connect to the wifi...coz its lock i forgot the password
You can either connect to the router by Ethernet and change the wifi password or You need to reset the router, typically by pressing the small button on the back for 15 seconds.
Feb 28, 2011 | Computers & Internet
Port opening
You can open port number for the game in following way.
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.1.254.
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is admin, and the password is admin. Click the Ok button to log in to your router.
Please visit our default username and passsword page, if the username and password shown above did not work for you.
Click the Customized Configuration button.
Click the Advanced link near the top of the page.
Click the Virtual Server link near the left of the page.
Enter the port to forward into the Public Port and the Private Port boxes. Select Both from the Protocol drop down box. Enter the ip address to forward these ports to into the Server IP box. If you are forwarding ports so you can run a program on your computer, you should enter your computer's ip address into that box. Put a checkmark in the Enabled checkbox.
When you're finished, click Save near the bottom of the screen to save your changes.
Hope it can resolved your issue
Thanks for using Fixya
Apr 09, 2010 | MSI Wireless-G RG54G3 Router
NetGear DG834G Router Logo
91 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
