Question about Dell W2306C 23 in. HD-Ready LCD Television
AV side component, and cable thing don't work
All i see is grey fuzziness, i can still hear it... just can't the picture
  • DeXxTeR025 Feb 11, 2008
    no it's for my ps2... like it works for other tv's just not this monitor (dell W2306C)
  • dmvai Mar 14, 2008
    My TV is hooked up to cable. Has been working fine for a year and suddenly the picture is all grey. I can hear it, but there's no image. Cable guy changed box and cables and theres no change. Help!
Per the tech at Dell today, the intergrated video chip is bad. The cost for shipping it back for repair ($234) not worth it! Will check to see if it can be fixed locally.
Posted on Dec 06, 2009
    Master:
    Sergeant:
  • 440 Answers
What using dvd player ? set dvd to progresive scan output use red green blue outs select right input on the tv ok
Posted on Feb 11, 2008
I'm trying to hookup my Toshiba DR430KU to an older tv that require an RF Modulator. I get a skewded sideways picture. Does This DVDR compatable with a RF Modulator?
Probably not. Better picture results are achieved with either S-Video, standard RCA AV cable (yellow-white-red), or YUV component cable (red-green-blue) (component output does not have audio - this requires extra cable to be connected). The video via either one of these 'AV' connections is stunning (based on a standard 16:9 LCD TV using a Panasonic DVD recorder).
RF tends to be lower quality - as opposed to AV/digital input. AV input/YUV component handles digital better. No one connects their DVD devices to their TV via RF (either directly to the antenna socket or with a modulator/attenuator) anyway. Because a VCR is mostly analogue, it will work fine with an RF connection, but DVD is digital, and so won't work as well, if at all.
RF also goes through the tuner in a TV, creating cross-interference, whereas AV is a direct input and is separate to the tuner.
I would say an RF modulator would not be designed to handle the output frequency that your DVD device generates. Throw the modulator out, or perhaps get another TV, or use RCA cables instead if the TV has AV inputs. Whichever is cheaper and easier, but don't use RF accessories except a standard antenna if/as required.
Apr 27, 2011 | Toshiba DR-430 DVD Recorder
Picture went completely fuzzy. What could the problem be?
The tv CRT( picture tube) have a radiaton posion infected in ur tv picture tube.This is how u discharge the CRT(picture tube) get the posion out.Take the tv back cover off.Take video board that connected to the CRT(picture tube) out.Plug it in,so u have a live current to the CRT(picture tube).Find a wire like an AV cable,should be find.One side of the metal,grounded to the metal frame somewhere.Take a long needle plier grab the other side of the AV cable wire,not the metal,(Caution high voltage live current).Come very close to the open CRT(picture tube).U will have a live current arc,than u,will hear a big "POP".U,just discharge the CRT(picture tube).The tv now the CRT(picture tube),now it good,it clear of posion infected in ur tv picture tube.Now,unplug ur tv.Put ur tv,back together.Hook up ur tv signal cable and plug in ur tv,now ur tv picture,will be clear,completely.I do this many times to dicharge fuzzy CRT(picture tube).When i was a tv Tech.for the SONY TV Corporation.
Oct 12, 2010 | Sanyo HT32546 TV
Fuzzy picture on PS3.
my ps3 just switched from a component tv to hdmi but the screen is fuzzy and off color and i've tried reseting the system but it's not working. help?
Dec 30, 2009 | Sony Playstation 3 (PS3) Console
No picture
First thing to check is your AV cable. Check for any worn pins or misalignment on the connector. If you'll find the cable to be broken, there is no choice but to replace it with a new one.
Oct 02, 2009 | Video Game Consoles & Games
No picture or sound
Your display needs to be reset, Turn the ps3 off. Then turn the ps3 back on but continue to press the power button until you hear the beeps then it should work fine :)
Aug 05, 2009 | Sony Playstation 3 (PS3) Console
All (4) video inputs are bad
possible change your AV cable...you can't use the same component cable for the normal AV input...component cable (RGB - RED,GREEN AND BLUE),normal AV cable is RED,WHITE,YELLOW.
GOOD LUCK.
Dec 09, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Screen was all fuzzy and red ring was at bottom right side!
from the description you stated it sounds like the following error code
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
  1. Try restarting the console.
  2. If restarting the console does not resolve the behavior, follow these steps:
    • Turn the console off.
    • Unplug all the power and AV cables from the console.
    • Unplug the power cord from the wall socket.
    • Firmly reconnect all the cables.
    • Turn on the console.
  3. Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green
try that and if nothing works I have more to follow.
Sep 16, 2008 | Microsoft Xbox 360 Console
Fuzzy picture and no sound
if it has av cable inputs on the console then its a modified system, and chances are something is either loose inside or fried.
Jul 25, 2008 | Sega Genesis Console
Fuzzy picture
You might want to try a new cable, otherwise it might be a loose jack that if your daring enough, you could fix yourself
Jan 09, 2008 | Zenith D65W25 TV
Weird problem not convergence
Mine is doing the exact same thing! have you found a fix yet?
Apr 23, 2007 | JVC AV-48WP74 48" Rear Projection...
Dell W2306C 23 in. HD-Ready LCD Television Logo
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
