Question about Toshiba Satellite L20-S310TD Notebook
Toshiba Satellite L20-101.
Recently I have deleted some programs from the combuter and I have realised that the CD/DVD is not working. I have checked the system device manager and it shows a question mark on the CD/DVD device. What can I do in order to fix it?
Thank you in advance
  • gtgtgt Feb 11, 2008
    Thank you very much for your help, but that is not working. The symbol of CD/DVD still appears with the exclamation mark.
  • 4 Answers
Restart your pc go to control panel >add remove hardware>select the first option add troubleshoot a device>then reinstall you dvd and cd drive.
regards
gaurav
Posted on Feb 11, 2008
It may be a driver problem
Get "Driver Detective" .it will detect the missing driver and download it for you
Posted on Mar 06, 2008
Toshiba satellite l655d-s5093 d: drive issue
Buy a drive cleaning CD/DVD, those from dollar store may also work, clean the drive a few times and it should read CD/DVD.
Alternatively look at the Toshiba support drivers fro firmware update to your specific drive. Make sure you get all the recommended and critical Toshiba updates.
Regards, Mike
Jan 19, 2012 | Toshiba Satellite L655D-S5093 Laptop
Hello, the cd/dvd drive in my satellite A105 S4334 laptop is not reconized by the computer, it has power but it doesn't show in My Computer
One of two things are wrong.
You could have a bad setting in your registry. Download and run CDGONE. One place to get this utility is: http://www.geekstogo.com/forum/files/file/8-cdgone/
The other possibility is that the CD has gone bad and must be replaced--a relatively simple fix.
Feb 18, 2011 | Toshiba Satellite A105-S4334 Notebook
Is there a destructive recovery option on toshiba satellite a105, i have no recovery cd
I'm not really sure what you are asking. If you see an option on startup that says something like press f11 or something for system recovery, then you can recover from the recovery partition--assuming there is one.
You can probably order a recovery CD or DVD from Toshiba, also.
Nov 12, 2009 | Toshiba Satellite A105 Notebook
Dvd driver of toshiba
THere is no need to get DVD drivers as they are included in standard windows package and are integrated.
In case you have windows Vista installed and dVD is with exclamation mark in Device manager you jut need to delete upper and lower filters in regestry.
Step 1: Start Registry Editor
Click Start, click Run, type regedit, and then click OK. Registry Editor starts. (In Vista, right-click Registry Editor, and select Run as Administrator)
Step 2: Delete the UpperFilters registry entry
In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
Expand SYSTEM, and then expand CurrentControlSet.
Expand Control, and then expand Class.
Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak.
On the Edit menu, click Delete.
When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:
Are you sure you want to delete this value?
The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step.
Step 3: Delete the LowerFilters registry entry
In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear.
To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak.
When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry:
The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Exit Registry Editor.
Step 4: Restart the computer
Important: If a CD recording program no longer works after you restart the computer, you must reinstall the CD recording program.
Sep 14, 2009 | Toshiba Satellite A105 Notebook
Toshiba Satellite P105-s6147 CD/dvd drive some how uninstalled
Registry edits not usually a good idea. System restore is your friend. Some DVD burning apps will change your registry and cause the CD/DVD to disappear. Uninstall the new burning app, or system restore to a time you know it was working.
Jul 24, 2009 | Computers & Internet
Dvd and card reader not working
Go here, choose Portable, Satellite, and your model.
Your drivers can be found there.
Mar 21, 2009 | Toshiba Satellite P105-S6104 Notebook
DVD drive on Toshiba Satellite M35X-S311 not working
Ooops! Hate it when I delete necessary stuff !!! Go into the device manager and uninstall the optical drive (cd/dvd drive), then reboot. It should find the drive and reinstall it. If it doesn't, then do a hardware search from the device manager. If it still doesn't find it, then do a system restore to a point before deleting the files.
Jul 15, 2008 | Toshiba Satellite M35X-S311 Notebook
Toshiba Satellite Pro L20 fitting DVD Writer
Try to find the correct driver from Toshiba for the driver, your current one wont work for the dvd.
Mar 27, 2008 | Computers & Internet
CD/DVD stopped working...device driver unable to be loaded.
Try cleaning the lense / As well install correct driver also; If nothing works out best alternative is to replace the CD/DVD rom with new or working once.
Mar 18, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite pro hl-dt-st dvdram gma-4082n
goto program defaults/media player/disc insertion= and choose the options you require. Or goto computer-cd/dvd drive and choose the program you wish to run the disc
Dec 10, 2007 | Toshiba Satellite A135 Notebook
Toshiba Satellite L20-S310TD Notebook Logo
1,142 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
