Question about GE 31GT660 TV
GE model 31GT660
I have this GE, and it works fine, but has what looks like a gray film, or cloud over the picture. The fog/cloud is even, and the picture is fine. Just foggy. Help Please...as others, I just want to know if it's worth fixing.
Thank you for any answers!!!
  • Ami Foggy Feb 11, 2008
    thank you SO much for being so quick!!, im a silly woman, so bare with me..I see the controls, screen and focus, but i cant get them to turn. Am I missing something?
    Also, I see a pattern of lines now. Foggy grayish white lines..I didnt see them before...
    Genius:
  • 1,694 Answers
Is the brightness in the middle of adjust range? Is the picture
or contrast adjust at 3/4 ? Next,adjust the screen voltage on
lower rear of cabinet = one control is focus and one is screen..
how is the picture now ?..........................T.
Posted on Feb 11, 2008
  • Vista Electronics Feb 12, 2008
    Look with bright light....if screen adjust doesn't clear it up,
    then Q901 brightness limiter transistor may need changing by
    a skilled tech.......or screen voltage resistor is out of tolerance..
    .....................................T.
What would cause a GE 60GW948 have a very snowy, and now No picture screen
when you say gone out---no light on screen or brightness or what? The snowy picture can be got around in most cases.
Jun 14, 2012 | GE 31GT660 TV
My Old 1997 GE 31GT660 was working just fine yesterday with a PS2. My girlfriend moved it today while cleaning and now I cannot get the PS2 to work. We have no remote but a friend used a universal to get...
Ur girl friend clean around did she unplug the tv.Replug it back later?Bet u she did,that why the tv universal codes is gone.Reprogram ur tv unverisal codes again should solved this problems.Tries push the manual control button channel up like one or two times tv will be in input video again like video 1 or 2.
Jan 13, 2011 | GE 31GT660 TV
Cannot change from video mode as we have no remote. We have a GE TV model 31gt660 which was hooked up by Direct TV. However, when the boys decided to hook up a flat screen to watch the fights the GE was...
My only suggestion would be to purchase a multi-functional remote that you could program to your TV. Now some remotes have to be programed buy your old remote. That is not what you need. You need the kind that comes with a little book that will list your tv model number and give you a code (usually 4 numbers) to teach it to talk to your tv.
Sep 20, 2010 | GE 31GT660 TV
Remote code for GE TV M#31gt660
It depends on which universal you are trying to program. There is not a set code for all remotes. Every universal manufacturer has there own set of codes. Thanks for using fixya.
Nov 15, 2009 | GE 31GT660 TV
Audio on my GE television has went crazy
Well you going to need a new tuner! Let me tell you now that digital is out or is comming your not going to find the part!!! Well if this has RCA inputs your in luck you buy a digital box around $60 bucks then put the tuner on it and you in luck and you saved your TV!!
May 25, 2009 | GE 31GT660 TV
Ge 31gt660 tv
I had the same issue, turns out all I had to do was change the channel to 00, then my games or whatever I hooked up to the component inputs in the back worked like a champ.
Hope that helps.
Jan 25, 2009 | GE 31GT660 TV
Help
use tv/video or input button to switch to av input
May 07, 2008 | GE 31GT660 TV
Vertical size adjustment on my GE 31GT660 set
I had the same problem. I found the solution in this link.
http://www.techlore.com/forum/thread/13480/?page=1
The only thing that wasn't clear was how to get into the service menu. With the TV on, press and hold the MENU button on the front panel of the TV and press POWER then press VOL+.
Dec 01, 2007 | GE 31GT660 TV
GE 31GT660 picture is intensly WHITE
The GE (actually RCA) 31GT660 uses the CTC187 series chassis. This chassis is notorious for bad solder joints on the shields around the tuner and microprocessor. When the solder joints on the shields crack, the microprocessor and EPROM lose their ground and the EPROM's data becomes corrupt. The solder joints on the shields will all have to be resoldered and the EPROM reprogrammed or replaced by a qualified tech familiar with the 187 series chassis.
Aug 22, 2007 | GE 31GT660 TV
GE tv modle 31gt660
have tech repair your tv the video circuit or related circuit is defected.good luck.
Jun 03, 2007 | GE 31GT660 TV
GE 31GT660 TV Logo
88 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
