Question about Acer Aspire E380-UD420A (ASE380-UD420A) PC Desktop
No internet to the computer
Model Number ASE380-UD440A Can't connect to the internet. The internet is working but it says failed to detect internet connectivity. I typed in the ISP and Password and still doesn't work. Need help.
  • Nomorepandas Feb 19, 2008
    Computer connects to the Internet but gives the error details:
    Componenet GUID: {7071ECA3-663B-4BC1-A1FA-B97F3B9173}
    Componenet file: [C:\windows\system32\connect.dll]
    Error: (0x800706BA)
    The error message could not be found.
    "Failed to detect internet connectivity."
    My machine is an Acer Travelmate 5510, but has the same problem described here.
  • 92 Answers
If you already created a new connection and went through that process, just simply call your ISP they will easily solve the network issue for you.
Posted on Feb 11, 2008
What is the case fan size for a acer aspire ase380-ud440a desktop computer? Also what size is the CPU fan?
no need to replace just remove the label sticker from the fan and remove the smaller lock from the fan shaft be care full its very typical to remove that lock just use 2 needle with one needle press and hold the lock with other lift up lock from the cut side lift up the lock and remove the fan from bushing just clean both bushing and fan shaft with any rust remover cleaner clean well after clean both just apply any kind of lubrication oil and re assemble the fan it will be free of noise.
Jul 14, 2014 | Acer Computers & Internet
How to remove front panel to repair the front usb ports on an Acer Aspire E380 -?
The front USB connectors are usually either molded into the front case or held in via a clip or screws. Unfortunately, when they go out due to the tab within the USB port breaking, they are not easily replaced as each manufacturer creates their own proprietary connector...not the USB part but the hardware to hold the USB in place. So you will find the hardest part of this project finding the right connector or "jerry-rigging" the new one to fit.
Another alternative is to remove everything from the old case...the mainboard, all the drives and whatever else can be moved, and put it into a new case. If your current power supply is good and of a standard size, can get a used case for around $10.00 and put all the other things from the old one in it. Fortunately, this series of Acer seems to be pretty much generic so everything should fit....just make sure the "new" case has good front USB ports.
Jul 12, 2014 | Acer Aspire E380 ASE380-UD500A PC Desktop
How do I remove the front panel of Acer Aspire ASE380 desktop computer? They are not working.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
What could be causing a load whiring sound in Acer Aspire ASE380-UD440A
The CPU fan. This is normal. Use canned air to blow dust out if it has become louder than usual.
Oct 08, 2012 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Acer Aspire 5733 Wireless connection lost
Check the wireless router and high-speed modem.
If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
Activate the wireless Internet connection on the laptop computer.
Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu.
Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
Select the appropriate network you wish to connect to.
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
Restart the computer.
The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
hope this helps
Sep 13, 2012 | Acer Aspire 5733 Laptop
MSI Wind U135 wont connect to wireless internet
Try disabling ALL encryption and MAC filtering on the router and see if you can get it to connect that way. This is most frequently a mis-matched encryption or MAC address issue.
Oct 03, 2017 | Computers & Internet
Drivers for Optical device.
Hi, click to open the Computer Properties, by clicking on the computer if on your "Desktop" or click on the "Start Button, in the (right pane) select to open the computer. Check to see if there's a DVD RW Drive (D:) in the "Device with Removable Storage area." If the area is (Blank)? Go to and select All Programs, after clicking on the Start Button; scroll to find the Media Disk Player. You made need to (Setup) your player, just open the Player and select to "Setup / Install, follow all the instructions, remember to click on the Apply and OK buttons when finished, and lastly, restart the computer. "Rating the solution for its helpfulness is appreciated, thanks."
May 14, 2010 | Acer Aspire E380 ASE380-UD500A PC Desktop
Aspire ase380-ud421a cd/dvd drive stopped working
Try going to system setup by hitting Delete when you see the acer/aspire logo when you restart, then open your drive there. If it doesn't work, it is likely that your drive needs to be replaced. You could also try reseating (pulling out and putting back in) the cables inside the computer that's connected to your drive. All else fails, replace the drive.
Dec 19, 2009 | Acer Aspire E380-UD420A (ASE380-UD420A)...
I have a ASE380-UD440A PC. I need Pwr Supply wiring diagram.
It should follow the standard AT or ATX convention try this site
click on power supply connectors
Mar 14, 2009 | Acer Computers & Internet
Acer Aspire  E380-UD420A (ASE380-UD420A) PC Desktop Logo
113 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
