Question about Eureka Atlantis 2595A Upright Wet/Dry Vacuum
Eureaka Atlantis Opti Heat Upholstery Cleaner
Water leaking out carpet cleaning part on floor when using upholstery cleaner attachment
  • Ladybug Sep 03, 2008
    My problem is with this forum. Why have questions with no answers?
    3 problems with my Eureka:
    It doesn't not heat up.
    It leaks sporadically and annoyingly.
    The upholstery attachment is ****. The button fails to perform adequately. Who lets manufacturers make these things?
    Eureka Atlanta 2596 Opti Heat
    By the way, I contacted Eureka about my problem, I think EVERYONE on this site who has a new or next to new Eureka should contact them and let them know all the problems you are having. I believe you may be able to get a new machine if you talk nice to them about the problem. DOn't quote me on it because I am in the process at the moment.
SOURCE: EEureka Atlantis 2595A Upright Wet/Dry
I have an Eureka Atlantis Deep Steam Extractor and it does the same thing. It's not new but it hasn't been used much. The only thing the booksays is to put the tank in until it snaps into place. (Like we didn'ttry that.) Apparently it's a bad design. The seal on mine looks fine.
If I was doing the floor I'd just keep going but I'm trying to do my couches and I don't need a huge puddle on the floor.
Posted on Nov 07, 2007
SOURCE: Hoover Upright SteamVac Deluxe with stair and upholstery cleaner
The original problem was, How do I attach the upholstery attachment to the cleaner. I see where the water connection is, but not where to attach the hose part.,
The solution to attaching the upholstery attachment to the Hoover Steam Vac cleaner was excellent for steps 1 and 2. However, in step 3, I can not simply slide the upholstery attachment straight down. It gets stuck and does not connect to the bottom connector and is stuck in midair. It seems like I am doing something wrong. My Hoover model steam vac model number is F5900-900.
The solution given in steps 1,2, and 3 where I have a problem with step 3 is as follows;
What is NOT easily visible is the connection for the vacuum hose. That's because the machine needs to be "reconfigured" before the hose can be attached. To "reconfigure" the machine:
1) Remove the cover off the waste water tank and notice how things appear--it will soon be important.
2) Find and remove the "panel" on the front of the waste water tank by sliding it straight up and out.
3) Replace the panel with the connector by sliding it straight down. When finished the top should look something like it did in step 1). This assures that the dirty water will be vacuumed into the waste water tank.
Done!
Posted on Feb 16, 2008
SOURCE: Eureka Atlantis 2591A Extractor - Won't spray
no sray water
Posted on Jul 23, 2008
SOURCE: Hoover Steam Vac
how do i get a manual on how to operate my hoover steam vac dual v spin scrub heated cleaning machine. i bought it used at a flea market and they did not have the manual. can you help me.
Thank you nessa
Posted on Oct 22, 2008
RockyNR1
  • 324 Answers
SOURCE: how do i attach my upholstery cleaner to my kirby generation 4?
Upholstery shampoo manual HERE.
Good luck,
Rocky
Posted on May 29, 2009
Cleaning solution does not come out
When you are using upholstery hose the water/solution does not go through the heater so see if water sprays out of upholstery attachment (this may take a little while for water to travel the distance). If it does than you know your pump is good. If water does spray out of hose but not out of bottom of unit it will more than likely be a clogged heater unit caused by water calcification or detergents. This can be cleaned out however it is not an easy job. And, if the heat insolators are not placed exactly in place, it can lead to plastic melting.
Feb 04, 2016 | Bissell 9500 ProHeat 2X CleanShot Upright...
Why is water pouring out the bottom when I try to use upholstery attachment?
On many hoover models the hose attaches to the vacuum and is held on by a clip on the hose assembly. There may be some damage to your hose or the place where it attaches to the machine. Inspect these areas trying to locate the point of the leak.
Feb 25, 2015 | Hoover SteamVac Carpet/Upholstery Deep...
How do I hook up the upholstery cleaning attachment
Right, how to hook up the upholstery cleaning so the water will drain?
Sep 20, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
How to hook up tool to clean upholstery
Keep your upholstered furniture looking fresh by vacuuming it regularly with the upholstery tool attached to your vacuum's hose. Prevent the fabric from fading (or at least delay this) by keeping your furniture out of direct sunlight -- close blinds, shades or curtains when the sun shines most directly through windows closest to the upholstery. And remove stains by blotting them with a dry cleaning solvent. Before steam cleaning your upholstered furniture, read the piece's cleaning code label to determine whether or not it is safe to do so. Then rent or buy a steam cleaner (also called an extractor) and follow the directions below.
  1. Rent a steam cleaner or purchase one; buy steam cleaner solution.
  2. Step 2 Vacuum the upholstery on the furniture you wish to steam clean; use the upholstery attachment to most effectively **** up loose debris.
  3. Step 3 Test the steam-cleaner solution on the upholstery in an inconspicuous place to ensure the color won't be steamed out or drastically altered.
  4. Step 4 Attempt to remove any stains with a stain removal or dry cleaning solution. Follow the directions that come with the product you choose for the best results, and allow the stain remover to dry before you begin steam cleaning.
  5. Step 5 Remove cushions and, if necessary, arm covers.
  6. Step 6 Gently apply the steaming water and cleaning solution in straight lines across the upholstery one section at a time.
  7. Step 7 Use the cleaning extension on the steam cleaner to **** up as much water as possible. The dirt will come out with the water.
  8. Step 8 Clean one side each cushion (then allow it to dry) before cleaning the other side. If the cushions are permanently attached to the furniture, clean them last.
  9. Step 9 Allow the furniture to dry completely before repeating the steam-cleaning process or replacing the cushions.
Jun 19, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Water leaks out under the unit when using the upholstery attachment?
You may wish to check and see if the leak is where the small water supply hose is plugged in to the cleaner base. That connecction supplies water from the product, to the spray end on the upholstery hose.
Sep 30, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Instructions on Using The Hoover Steamvac Ultra cleaner
CARPET CLEANER\r\n™
i went the xtra mile to look this up you give me a incorect modlel # put the user guide are the same ps: dont for get to vote for me when it ask if i helped you lol sawdust46
MaxExtract™ technology features the most advanced
combination of multi-action agitation, carpet washing, dirt
removal and direct heat drying - all in one machine. This
technology delivers a floor that is not only deeply cleaned,
but a room that can be lived in again within hours!
• High intensity LED
- illuminates problem areas
• Stream Setting
- ideal for smaller spots
and stains
• Spray Setting
- attacks heavy traffic areas
Dual scrubbing1, multi-directional
brushes have been specifically
engineered to surround carpet
fibers, removing dirt at every angle.
1Patent pending
High velocity suction removes both
dirty water and soap residue, leaving
carpet revitalized. Forced heat further
speeds the drying process. No sopping
wet carpets. No musty odors. Just
clean carpet.
STREAM
SPRAY
REMOVES MORE DIRT2
INTEGRATED SPOT CLEANING
2Test of leading brands of household extractors using FCTP-0024p
Our exclusive pre-programmed
cleaning modes take the
guesswork out of revitalizing your
carpets. Simply select your carpet
type and cleaning task, and let
the pre-programmed modes take
care of the rest. Fully equipped
with Process Feedback Lights
and Full Tank Indicator Lights,
this Intelligent Cleaning System
makes cleaning your carpets
easier than ever before.
HOOVER PLATINUM COLLECTION™ DETERGENTS
TO MAXIMIZE CLEANING PERFORMANCE
PROFESSIONAL STRENGTH
Carpet and Upholstery Detergent
PET PLUS
CARPET CLEANER
Instant Stain Remover
Carpet and Upholstery Spray
AN EFFORTLESS CLEAN
CONVENIENCE IN HAND
Powered Scrubbing Tool,
Upholstery Brush and
Crevice Tool included for
cleaning fabric covered
items such as:
• Stairs • Upholstery
• Mattresses • Pillows
• Area Rugs
To learn more about the Hoover Platinum Collection™
visit www.Hoover.com ™ ®
Six new vacuums, six new standards of clean, and six
new reasons for Clean Freaks to Rejoice. The Hoover
Platinum Collection™ saves you time and effort while
giving you the confidence of knowing your home is truly
clean. Whether corded or cordless each item is distinctive
in both appearance and performance, offering best in
class cleaning through a combination of innovative
technologies and carefully engineered ergonomic design.
With the Hoover Platinum Collection™ you get fast and
effective deep cleaning so you can move on with what
is next in your day, knowing you have efficiently
accomplished the deep clean you desire. With these six
superior cleaners from Hoover®, it is a wonderful time to be
a Clean Freak, and a terrible time to be a dirt molecule.
EXCLUSIVE HOOVER PLATINUM COLLECTION™ MEMBER SERVICES LINE:
1.877.MYPLTNM (1.877.697.5866)
Hoover®’s Best In Class,
Limited Six Year Warranty
Jul 11, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Hoover SteamVac Deluxe
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=624426
Posted by providence51 on May 26, 2008
My cleaner is not dispensing the shampoo solution. Still sucks up the dirty water that I manually applied with a scrub brush. I use this on my tiled screen porch floor and it has worked great many times.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There is a release value in the bottom the holding tank that may be bad and not opening or the trigger assm in the handle may be broken and not connecting to release the water to scrub and clean the carpets. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Cleaning uphoustry
I CANT FIRGUE OUT HOW TO PUT IT TOGETHER
Mar 05, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Eureka Atlantis 2595A Upright Wet/Dry Vacuum Logo
110 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
