Question about Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100
After I properly shut the computer down for the night. The next day the power button on the tower is flashing yellow every 10-15 seconds and the computer will not turn on. After about a day I am able to turn it on.
Please help...
    Master:
    Sergeant:
  • 440 Answers
Buy new power suplly for it ok
Posted on Feb 11, 2008
Hello, Last night I shut down my Dell E510 desktop - the proper way - by going to the start menu, shut down, turn power off. Then, today, I pressed the power button on the front of my tower and...
This sounds like a definite power issue. This means that the problem could range from being as simple as the power button itself not working/disconnected to the power supply being dead.
Things to try:
1. Have the side of your computer open and press the power button. Notice if any fans start to move or anything that happens.
2. Do you notice the Hard drive light flashing at all when turning on?
3. Has anyone else been using or been close in proximity to the computer that could have bumped it, causing something to come loose?
4. ONLY if you feel competent enough, check the cable connections inside the computer. Make sure to disconnect from the wall for 30 seconds and reconnect before touching any cables inside. Leaving the cable connected allows the computer case itself to act as a ground to prevent static shock.
Dec 23, 2010 | Dell Dimension E510 PC Desktop
My Desktop will not power on! When I press the power button it turns yellow but wont come on. If I press and hold power button, the yellow light goes out and a green light in the rear of the tower...
Please click this link Dimension 5100 and it will take you to the Advance troubleshooting guide for your Desktop. Browse for the Diagnostics light as this will let you know what is wrong with your computer. Most likely this kind of issue pertains to a Memory or RAM issue which can sometimes be resolve by re-seating it. For further details of your computer, follow this link.
Aug 18, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Hello, the green motherboard light on the computer
If there is no loss of functionality then I would say no.
Sep 26, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 - Will not turn on
open cpu cabinet.
Reattach ATX power supply connection to motherbord. ATX from SMPS to motherbord.
then check if it still not power ojn then clear cmos.
Pul away your cmos cell for 15 minutes from motherbord then check .
ALso change cmos cell if it is old.
Jun 26, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Desktop Dimension 5100 is not booting up
please check first your bios settings.. its could be on the boot up settings. you must configure it out correctly..
May 11, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell 5000 Dimension starting issue
You need to change your power save options. Right click on the desktop, click properties, click tab screensaver click on power tab. set the desired power save functions. hope this helps
Feb 24, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell 5100 won't start... Power button blinks yellow.
hi disconnect pc and try to charge ups without anything connected
Dec 04, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 power up problem
I had same issue with dimension 5100 Desktop. I work at Circuit City as the Lead Technician. I found that swapping the power supply did fix the problem! When i initially tested the power supply with a standard power supply tester, the power supply appeared normal. But after swapping the PC works great. Thx for the good idea!
Sep 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
166 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
