Question about JVC AV-27530 27" TV
Get get any responce on my JVC AV27530 27" TV
TV was running just great only a few years old all of a sudden you turn it on and the volume goes up to the max and you can't change the chanels or turn it down. Also it doesn't give you any picture it's just snow?? Any suggestions
  • 50 Answers
,,always unplug the set from AC,leave off a few minutes,,then re-plug back in,,that resets the micro--also,it could be the volume up button stuck-that would kill the other keys from working--you could try with a tooth pick to pull VOL UP back----THIS IS DANGEROUS --SHOCK HAZZARD!!! if someone is technically incline,with the back of the tv off,,turn set on and unplug the keyboard plug from the main circuit board while the set is playing--then use the remote and see if the fuctions returned-THIS IS DANGEROUS-SHOCK HAZARD---I REPEAT -DANGEROUS!!!! PLEASE BE CARFULL,if that cures the problem-you have a bad keyboard-you can just leave it unplugged and use the remote----JUST BE CARFULLLLLLL
Posted on Mar 22, 2008
Jvc projection tv
Glad you got it fixed and this is a common issue in everything from TV sets to desktop computers--cheap caps dry out and fail.
Jun 09, 2012 | Televison & Video
My 2 year old tv has just started to go wild. Just put it on today and where u select the source on the menu option, this keeps scrolling through.. no responce from the remote and when switched off at the...
Hello mrdavidmetca,
Welcome, and thank you for using FixYa!
I would start by pulling the batteries from the remote control. Manually turn the TV off and then back on, manually. If the issue resolves, replace the remote.
If the issue continues; you will need to find a local TV Repair Shop and have the Tuner Board replaced.
Have a great day!
Sep 09, 2011 | Televison & Video
Cannot get home theatre to work with panasonic flat screen. Surround sound was working with old tv got a new one but now its not working. Do i need a different cable
your new tv probalby has an hdmi output. depeding on how old your jvc system is, iit may or may not have an hdmi input. not to worry, there should be some type of compatible output on the tv to send audio signal to the jvc. first look at the back of the jvc and see whats there. then look at the tv and you should see compatible output on tv and run proper cable to input on jvc. some auxillary audio outputs on the tv are driven by the volume of the tv itself, so make sure to turn the volume on the tv up a llittle to make sure its sending signal. you may have to go into the tv menu and turn the internal tv speakers off so you dont hear them and the jvc. its not a big deal if your hearing both, it just wont be true surrond sound. if it were mine, id turn the tv speakers off.
Dec 24, 2010 | JVC TH-C40 System
Picture has lines and goes black after warm up
Try unplugging for 2 mins. Or press power button for 30 seconds. Your Light in the tv might be shot.... happens every 5 or so years.
GOOD LUCK
CNBY
Jun 03, 2010 | JVC RM-C18G-1H Remote Control
My JVC LT-42X579 42 in. LCD TV is only 13 MONTHS old and it suddenly won't turn on anymore. The blue power light comes on -as usual- but after 3 seconds, it will start blinking and it will remain that way...
I contact JVC and was told to first make sure your cable box or whatever you use to normally watch TV is powered on and is ready to work
He told me to unplug TV for 10 seconds at least. Then he had me press and hold down the "MENU and VOLUME DOWN (-)" buttons, at the same time for about 10 seconds. Then after 10 seconds of holding the 2 buttons down, he had me continue to hold the 2 buttons and press and let go of the power button. In other words after 10 seconds of holding down the volume down (-) and menu buttons, add the third button (power) and immediately let go of all 3 buttons, at the same time.
It worked for me instantlynd hopefully it works for you!!!
Nov 20, 2009 | JVC LT-42X579 42 in. LCD TV
Big screen tv turns on and off on its own!
Your TV is being overheated by the location it is placed. try moving it in an airy area and see if the problem still occurs. The turning on and off is a response to overheating sensors in the TV housing and if not rectified it could malfunction and may cause burnout, a possible risk of fire.
Sep 18, 2009 | Proton MM2701VT 27" TV
JVC TV crisis.....HELP
yes... i actually work at verizon the tv is to old for fios because fios is so advanced we run off ot 720 to 1080 depending on areas. what kind of box is it? is it the hd box or stb>
Feb 13, 2008 | JVC AV-32230 32" TV
Tv volume goes down of its own accord
Some dust in the button to lower the volume on your TV or on your remote control might be causing it to think it's being pressed. Try playing around with it, pressing it hard so as to relieve it of any pressure on the inside.
Jan 09, 2008 | Televison & Video
Picture blacks out after a few seconds after turning on the tv
Anytime an LCD has a shade of pink, that means the CCFL lamps are about to go out. Now that you have a black screen, I'd say you just need some new bulbs.
Dec 07, 2007 | JVC LT-32X576 32 in. LCD Television
JVC AV-27530 27" TV Logo
94 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
