Question about Acer Aspire 3050-1733 Notebook
Shift button stiff
I have to push down fairly hard to get my shift button (on the left side of my computer) to work. I tried vacuuming my keyboard but that didn't do anything. What is the issue? Do I have to send it in?
    Master:
    Sergeant:
  • 440 Answers
Buy new kb for it on line alot places iwll sell it ebay will take down rd or do it yourself pop old one out top panel off 1st that goes over the screen hinges lift that up flat head then 3 screws holding kb in lift out of ribbin cable clip its in to mobo u can see it its easy thx nick
Posted on Feb 11, 2008
I hav laptop acer brand wea the lfet side shift key not working wea as right side shift key is proper working..i need away out to hav the left shift key wrking
I would replace the keyboard. They are fairly inexpensive from that auction site flea bay and a video on how to do it is available on utube. Search for your make and model with the words 'replace keyboard' after it in the search box.
Dec 23, 2013 | Acer Computers & Internet
How do I remove the hard drive from a HP XH485 Pavilion Notebook
I think the HDD is under the keyboard on that model (doh!), which is probably why you're asking. If you can't find it under any of the access panels on the bottom, you're in for a bit more work...
1: Close the laptop and view it from the rear where all of the ports are. There are 2 hinges for the screen. Remove the 2 screws that are in those hinges. They are only holding a plastic cover in place.
2: With the screws removed, open the laptop and open completely, so the laptop is laying flat open. At the top of the keyboard is the button panel and removes fairly easily. Use a small and thin flat tip screwdriver to carefully lift up this panel. I started from the right side as it is easier to pop off. The left side is a little more stiff. Once you get most of the right side up, gently pull to the right and wiggle carefully top pull the panel completely off.
3: The set screws for the keyboard are now exposed. There are 4 of them. Remove them and you should easily be able to lift the top of the keyboard and fold it gently towards the front. Do not pull or disconnect the keyboard.
4: The Hard Drive should be completely visible now. There are 4 screws holding the caddy down. Loosen these screws completely. They should not come out. After the screws are loose, pull on the strap at the front of the caddy. Pull straight up firmly and carefully. You may want to jiggle it slightly to work it up, and be prepared for it to pop out on you. It can be in there pretty stiff, and you don't want to damage any thing.
5: If you need to, remove the drive from the caddy, take the connector on the drive pins off first, and then remove the 4 screws attaching the caddy to the HDD.
Closing it up should follow smoothly in reverse order.
Nov 09, 2011 | HP Pavilion xh485 Notebook
Will not load up or take charge
Try removing the AC power, removing the battery and then holding down the power button for five seconds. On the MacBook Air, press (left) Shift-Control-Option along with the power button once. Note: You must use the keys on the left side of the MacBook Air keyboard.
If that doesnt work try this:
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Mar 01, 2011 | Apple MacBook Air
When turn on MacBook air the screen is blue.I can't get into any icons.
Try to reset your SMC (System Management Controller) p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica; color: #1a1a18}
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 10.0px Helvetica; color: #1a1a18} span.Apple-tab-span {white-space:pre}
1. If computer is on, turn it off by choosing Shut Down from the Apple menu.
2. Connect power adapter to computer and to a working power source.
3. On built-in keyboard, press (left-side) Shift-Control-Option along with power button just once. Important: Use Shift-Control-Option keys on left side of keyboard.
Note: When the LED on the MagSafe connector is orange/amber, resetting the SMC will change it to green for a few seconds, indicating that SMC was correctly reset.
4. Wait 5 seconds and press power button to start computer.
If it starts without beeping errors reset the PRAM (Parameter RAM)
1. If computer is on, turn it off by choosing Shut Down from Apple menu.
2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in Step
4. Note: If keyboard does not have an Option key, use Alt key instead.
3. Press power button.
4. Immediately press and hold Command-Option-P-R keys.
Important: You must press this key combination before the gray screen appears.
5. Hold down keys until computer restarts, and you hear startup chime a second time.
6. Release keys.
Dec 31, 2010 | Apple MacBook Air
Dropped wireless mouse and wheel shifted & buttons hard to push
I had a similar problem and was able to fix it. The left mousebutton was clickable, but needed extra force.
After opening the mouse I found that at the side of the mousewheel there was notch pointing upwards, preventing free movement of the left mousebutton. I was able to rotate the ring with the notch back into horizontal position after gently pushing the housing surrounding the mouse wheel wider.
Apr 25, 2010 | Logitech Cordless Mouse
I have a Casio Privia PX-320. The left side keys
Check that the front of the keys is not hitting the lower plastic case front. If they hit it, then you need to disassemble the case partly and see what has shifted. It is ALSO possible that something has caaaused the aftertouch sensor to move out of position and it is hitting the keys early. ANY of these conditions needs to be addressed before damage is done.
Nov 30, 2009 | Casio Music
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Jan 02, 2009 | E-Machines eMachines Desktop PC
The page view on my HP computer is rotated sideways...the curser, the infor on the screen etc is a quater upside down...is there a setting to fix this?
Some videocards have keyboard shortcuts that can rotate your view. They normal consist of Alt Ctrl Shift and Left Right Up and down.
So start pushing some buttons.
Like Alt+Ctrl+Left
Shift+Ctrl+right
Shift+Right
and so on.
Dec 03, 2008 | HP VP6310 Multimedia Projector
Alternate keys on HP Keyboard
Activate:
Ctrl + fn + right shift key
Deactivate:
Ctrl + fn + right shift key twice
so hold ctrl + fn + right shift key then release the right shift key but keep holding the ctrl + fn keys down then push the right shift key again and that should deactivate it
Jun 09, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
Acer Aspire 3050-1733 Notebook Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
