I cannot get my ipod to turn on. I've tried charging it, but it won't turn on. I've gone through the support on apple.com, no luck. I did the trouble shooting, no luck. The warranty has expired and I can't afford to send it back to find out whats wrong with it. Please help, I am having song withdrawls.
Shelby
email me at..... [email protected]
SOURCE: IPOD Classic 80G apple icon then red x icon or restore in itunes
I know you tried to fix it, but trying multiple times may work.
The message "go to
www.apple.com/support/ipod" usually is preceded by, or followed by, the
Apple logo or the sad face icon. It directs you to the Apple support
site because either the iPod software is corrupted or their is a
hardware problem. You should try to reset the iPod (try several times). If that doesn't right the iPod, then try to restore it (which will erase the entire iPod and reload the software.
Follow the links above and see if that gets your iPod working. You might want to see if you can update the iPod/iTunes software or try this troubleshooting guide. If it is really a hardware problem then your iPod needs to be taken in for service.
SOURCE: how to insert songs/movies in 80GB apple ipod classic
Hi! You need itunes to transfer movies into your ipod 80 GB. And all movies should be in .mp4 format will only be synced with your ipod. You can find a .mp4 convertor from the link--
http://www.freedownloadscenter.com/Best/mp4-convertor.html
http://www.pcworld.com/downloads/file/fid,62105/description.html
SOURCE: Blank display on apple ipod
It sounds like your Ipod is frozen.
You can reset it by holding the middle button and the button above it for 15 seconds. It should power down and then you can turn it back on.
SOURCE: Hi My ipod classic will not boot up. The screen
It might be defective so send it to the company to replace it.
Be sure to connect the charging/sync cable directly to the computer, not a USB hub. Most hubs are don't provide enough power to the usb ports to charge the ipod. If you need a method of charging the ipod while away from the computer connect your sync cable to a device like these: Even the USB port on Apple keyboards is not able to charge the Ipod.
If you're using the computer to charge the Ipod, be sure it stays on, when computers go into sleep or standby modes they stop charging your ipod. You may want to use one of the options below to charge your Ipod when the computer is off or in a different location than the Ipod.
For use inside: Best prices for a Belkin brand power adapter for Ipod click here
For use in the car: Best prices for a Belkin brand car power adapter for Ipod click here
