Frame problem on LG CZ20 E60
Changed the frame and jungle IC no result, after I removed Q303 it came 25%.....any info??
  • 4 Answers
See if the fuse is well and Q303 again.or jungle IC is bad.
Posted on Feb 11, 2008
Telefunken crt model Ttv280 Frame collapse how will i know if is the vertical ic or the jungle ic
Absence of Vertical scan output signal. You have to check its vertical scan output section circuit to detect and rectify this fault.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Similar fault symptoms and repair work has been described by the author.
Jan 09, 2017 | Televison & Video
Lg crt 29 inch tv wont start
The frame amplifier, like the line amplifier, will not work if there is no output from the oscillators for them to amplify.
Early 405 line sets didn't have a frame oscillator as they used the sine wave from the AC mains but I believe the later sets needed a frame oscillator and a sync signal from the rf demodulator to prevent instability.
Transistors rarely fail by themselves and it is often external factors that cause them to overheat and fail and an essential part of the repair process is discovering what factors caused the initial problem. Modern circuits use a lot of multi-transistor dc coupled stages and it is often the bias of an earlier stage that is the culprit.
The frame output transformer is usually very robust and much less likely to fail than a line output transformer. I suggest you ensure the correct operation of the oscillators before going any further.
Aug 30, 2016 | LG Televison & Video
Bright lines in the center of the screen the height is insufficient.replacing Vertical ic La7830,and 3 or 4 condenser no good.Need schematic diagram try to search for the jungle output.tnx more power
This is the vertical deflection IC of a CRT color TV. If you think it is fried then replace it yourself. For a datasheet of this part check the following link:
http://www.rdd-tech.com/product/la7830
If the problem is the jungle output IC cxa2159s could be a problem and not start the power supply. This can cause an error code to know for sure.
Feb 10, 2015 | Televison & Video
My Sony Model # KD-27FS170 have 4 blinking error code, I have change IC Part # STV 9325 did not solve the problem
After changing the frame output chip, have you got any power going to it? Is there any frame pulses getting to the input of the chip? and have you changed the dried up capacitors in the frame stage?
Is the scan coil lead connected properly, they can get dry joints and go open circuit.
Feb 22, 2011 | Televison & Video
Horizontal line and no picture
You have "frame collapse" as it is known. Almost always a replacement Frame Output IC will fix this problem after the leaking capacitors have been changed.
Hope that helps.
Nov 17, 2010 | Toshiba Televison & Video
My 20 inch lg tv crt monitor will not show a
is video show on vcr player? if yes you need to replace jungle ic which is switching line from tv tuner to line in video.
Feb 10, 2010 | LG 42LC2D 42 in. LCD HDTV
How much does IC of lg television will be cost
Hi! it will depend of what kind of ic you want to purchase, if it is the system ic and jungle ic . its quite expensive.
Sep 19, 2009 | Televison & Video
Doesn't always turn on stand by light is red and blinks 7 times thank you angie (tumbleweed64@comcast.net)
Flashing 7 times is a fault code usually suggesting a fault within the frame stage (frame collapse). This is sometimes just a poor soldered connection around the frame IC so would therefore just need re-soldering. If not most likely the frame IC would need to be replaced.
Jun 24, 2009 | Sony Televison & Video
Hi I'm looking for spare parts to a Little Tikes Jungle Climber (plastic climbing frame - themed as jungle safari by Little Tykes Jane
Little Tikes sells replacemnt parts for all most anything. Have you checked their website? Look in the consumer section for replacement parts and then search by the type of equipment.
Jun 11, 2009 | Toys
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
