RCA P52754AT rear projection tv won't turn on
I shut the tv off and now it will not turn back on if you use the on off button or a remote it will flash green three (3) times and then stop, I pulled the front off and I can see the three boards that are trying to click on but set will not power up
  • 2 more comments
  • SLCRIC May 11, 2008
    I have the same problem. Has anybody figured out what the problem is?
  • George Vestal Jul 06, 2008
    I have the same problem. Help please.
  • Anonymous Oct 15, 2008
    same ..wont turn on
  • mrgoal00 Dec 19, 2008
    I shut the tv off and now it will not turn back on if you use the on off button or a remote it will flash greenthree (3) times and then stop, I pulled the front off and I can see thethree boards that are trying to click on but set will not power up
Good way to test for bad buttons is go inside the back and there is a black multi-wire cable that is connected "front and center" of the center lens on top of the chassis....easy to get to from the back.
Disconnect it....
I've had touchy switches on this unit that cause the problems you're seeing....and who uses the switches? Your remote will still function, and with the buttons disconnected, the microprocessor won't get stuck servicing a false command....which by the way makes it IGNORE the remote when they go goofy on you..... Source(s): Over 24 years servicing TV sets......
Posted on Apr 27, 2009
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
RCA P52754AT POPPING SOUNDS. COLOR FLICKERS AND
It sounds like your high voltage block is arcing and causing the TV to go into protection shutdown temporarily. If that's the case, you'll most likely need to replace that HVB.
The other thing it could be if you're hearing "popping" (snapping ?), is that one of the CRTs could be arcing to ground, maybe the green one since you're getting too much green.
Good luck.
Nov 28, 2009 | RCA P52771AT 52" Rear Projection...
Swirling colors unwatchable screen RCA rear projection 52"
I will assume it does this no matter what the input is, It sounds like the board that controls the projection lamps is causing them to misfire? Or light up out of order in rapid succesion? you will probably need to have the TV serviced, or at least an estimate, so you canfigure out exactly what part has gone bad,( hard to tell sometimes when were not there), but be carefull if you decide to service it yourself.
Apr 12, 2009 | RCA P52926 52" Rear Projection Television
P52754at
Sounds like the block has shorted,not sure if you can replace your self but part number is 205064,you have to remove the grill were the speakers are and behind the grill is a panel,removing this panel and there is a part between the left and middle tube with a bunch of red wires on it ,this is what i think is bad.
Mar 12, 2008 | RCA P52830BL 52" Rear Projection...
RCA P52754AT 52 in. No Picture No Sound
Sounds like the flyback failed,or a loose connt. on the high voltage area of the main board.
Jan 26, 2008 | RCA P52830BL 52" Rear Projection...
RCA P52753AT tv will not turn on
the High Voltage splitter needs to be replaced
Oct 06, 2007 | RCA P52939 52" Rear Projection Television
Televison & Video Logo
881 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
