RIM BlackBerry Curve 8310 Smartphone Logo
Posted on Jan 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I am at home my blackberry curve holds a charge for a couple of days. But when I go to work it last half a day to one day at best.
Anonymous
Level 2:
  • Expert 112 Answers
  • Posted on Jan 18, 2010
Anonymous
Expert
Level 2:
Answers
112
Questions
0
Helped
22571
Points
280
May be there is problem of tower or coverage in that the coverage is up down so the charge is usage more thats why this problem is there.
The screen is blank white. a charging icon in the center. when connected to desktop manager it doesnt connect. I can reload the OS but i need the data to be saved. Unfortunately i dont have the backup...
your blackberry got nuked. i'm sorry to inform you that the data on the phone WILL be lost, when reloading the OS.
there's no way that you can save the data other then the backup you've made a couple days earlier
tip
My AT&T Blackberry Curve does not charge anymore, is it the battery or the...
Hi.
Here a series of useful answers to common questions asked when an At&T Blackberry is not charging anymore.
1. My Blackberry is not charging anymore. Is it the battery or the charger?
Possible reasons are faulty battery, defective charger, bad contact on phone socket to charger.
When it is a charger problem, or a bad contact to charger, the phone will not detect that the battery charger is connected.
When the problem is the battery, usually you can see the charger beingdetected, and the charging line progressing, but the battery nevercharges.
The charger can also be tested using a Voltmeter. If the charge is in good working order, the Voltmeter will read a value within half volt from charger specifications.
2. Do batteries actually lose ability to work?
Yes they do, and the fault is not unusual.
3. How much will a new battery cost?
Most ordinary Li-Ion batteries for BB are sold at less than US$10. You can see a choice of sellers here: Blackberry Curve Battery
Ensure that the battery is compatible with your Blackberry model.
4. How much will a new charger cost?
The charger is also commonly sold at less than ten US$. You can see a choice of sellers here: AT&T Blackberry Curve's charger.
Ensure that the charger is compatible with your Blackberry model.
5. Will AT&T service the phone?
They will do, providing that the phone is still under warranty. Newwireless devices like your BB carry a one-year warranty from date ofpurchase. Refurbished devices carry a ninety-day warranty from the dateof purchase. If the phone had been purchased in US, to make a warranty claim after the first 30 days from purchase, you can call At&T at1-800-801-1101.
If the phone warranty has expired, a good choice could be going to anAt&T licensed phone shop, and asking to test battery and chargeron the bench before buying a replacement battery.
2helpful
My Tom Tom XL 325 wont hold a charge while left off
Hi, leaving the unit in the cradle exposed to the sun during hot days has been known to fry the battery causing loss of battery capacity. perhaps this could be your problem. I replaced the battery in my last GPS 4 times because of this before I analysed the problem. This will most likely be outlined in your user manual too. You might also compare the output capabilities between your blackberry and tomtom charger - it is entirely possible that you are starving the unit of a decent charge if the blackberry charger is not to the same current capacity as the tomtom charger.
I have a blackberry curve and when I turned it on after it being off and charging, a battery with a lightning bolt appears, but the phone will not turn on. Any ideas??
Battery power can be maximized by following these simple suggestions.
  • To delete a highlighted item, press the Delete key.
  • To select or clear a check box, press the Space key.
  • To view available values in a field, press the Alt key.
  • To switch applications:
    1. Hold the Alt key and press the Escape key.
    2. Continue to hold the Alt key and highlight an application.
    3. Release the Alt key.
  • Set the Auto On/Off option to turn off the BlackBerry smartphone at a time of day when you are not using it (such as at night), and turn on again at a time of day that you are ready to use it (such as in the morning just before you wake up). Battery power is saved by turning the power off at times when the BlackBerry smartphone is not being used. To set the Auto On/Off option on the BlackBerry smartphone, complete the following steps:
    1. On the Home screen, open Options.
    2. Select Auto On/Off.
    3. Specify the on and off times.
    If all this dosen't work please walk into the nearest service center to check you're blackberry Handheld battery is fine.
    Blackberry curve battery problem
    buy a battery if problem persists maybe time for a new phone
    1helpful
    How to manage BlackBerry Curve 8330 calendar from home PC desktop
    The blackberrys link to outlook and not their own calendar/contact manager. If you have outlook at home, you should be able to use the desktop manager software to sync with that.
    Blackberry Curve 8330 - Stopped receiving e-mail from one account (but not the other)
    The setting should be on your phone. Either delete the account on your phone and reset it up. Or check the email settings option.
    1helpful
    So my blackberry curve just crashed
    what has happened is some file some where is corrupt. It any easy fix really, just download your current os which you can find by holding down alt and then type eace and that will bring it up. download the os from here www.blackberry.com and then connect and reload your os
    2answers
    The battery life gor my blackberry curve 8310 is simply horrible!!
    I have a Curve too and my battery life has never been longer than 7 hours, I have to bring my charger to work to make it through the day. I am on my second battery too and no improvement. I have also taken off any programs that may **** battery life and its not helping.
    Top RIM Computers & Internet Experts
    ZJ Limited
    ZJ Limited
    ExpressFiX
    ExpressFiX
    Alexander
    Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
