Question about Microwave Ovens
Whirlpool Microwave Model MH3184XP will not power up after power failure
We had a power failure after a storm but the microwave worked fine. Then one morning a couple of days later the display had PF and the time. After coming home that afternoon, the display was blank. Check breacker and outlet and they are ok.
  • 1 more comment
  • Big Oz Feb 14, 2008
    The hard reset didn't work. My brother checked a fuse that was located in the top right corner behind the plastic grill and it was still good. No electricity getting to it though...........thanks....
  • Anonymous May 05, 2008
    no power at all. outlet good. main fuse good.next fuse seems to be open but i can't read the value need schematic
  • Anonymous Mar 13, 2009
    WHERE IS THE RESET BUTTON LOCATED???
  • Microwave Ovens Master
  • 9,098 Answers
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again. Let us know if the hard reset doesn't fix it.
If not, then you may have a problem is on the control panel, which we repair nationwide for $39.95 postpaid.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our
listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 13, 2008
  • William Miller
    William Miller Feb 15, 2008
    It sounds like you and your brother may be willing & able to check some things?
    If so, I would first refer you back to the safety information at my site linked above. Safety first.
    We also have disassembly info that can help. Essentially, you unplug the oven, remove the grille, then you'll see one screw holding the control panel on.
    Once that screw is removed, you generally lift up and out to ease the control panel away from the chassis.
    If you detach any wires, be sure you mark or photograph them to be sure every one gets back where it came from.
    Most recent Whirlpool microwaves have a "mini-manual" hidden behind the control panel below the control circuit board. It's very handy for troubleshooting.
    I would suggest that you check the internal fuse and the magnetron thermostat, then if it has one, the cavity or oven thermostat. All those should read "closed" or virtually zero on an ohmmeter.
    It probably has a hood thermostat on the floor of the chassis. It will normally read "open" virtually infinity on the ohmmeter.
    If the fuses, and thermostats check good, the problem may be on the board. Refer back to my previous posts if you think that might be it.
Whirlpool mircowave model MH3184XP the display reads F2
There is a problem with the control pad. The membrane, or surface, of the pad may be broken or damaged somewhere, resulting in the F2 error code. This is common for Whirlpool microwaves.
Press "Stop/Cancel" twice and select a new cook program. Press "Start" to begin.
If the error code persists, press "Stop/Cancel" again and unplug the microwave. Wait several minutes and plug it in. If the F2 code appears again, it requires repair.
Replacement membranes can be found online
http://www.appliancepartspros.com/whirlpool-panel-asy-control-8205376-ap3775860.html
but the internals of a microwave are dangerous, having high voltages even when unplugged. With the cost of parts and labour from a service tech, you may be best buying a new oven.
Sep 04, 2013 | Whirlpool MH3184XP Microwave Oven
Just quit working. No power. Unit is getting power but does not work
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Dec 27, 2010 | Whirlpool MH3184XP Microwave Oven
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
THE MICROWAVE WAS OFF WHEN WE GOT UP..WAS FINE LAST NIGHT, NOW NO POWER, LIGHT...NOTHING
first check the power to the outlet.
plug something else (that works) into that outlet to see if it has power.
Jan 24, 2010 | Whirlpool MH3184XP Microwave Oven
No installation Instructions or Owners Manuel
Although you gave an incomplete model number, Owners Manuals, Installation Guides, Warranty Guides and Part Lists can be found for the entire MH3184 series on this page: Whirlpool Product Literature/MH3184 Series
Hope this helps!
Aug 05, 2008 | Whirlpool MH3184XP Microwave Oven
Humming sound when off
I also have the same microwave model and with the same problem. It is not quite 2 years old. I have a service call scheduled but did e-mail customer service at Whirlpool to inform them of this. Sounds like it could be defective model and a fire hazard. You should also inform them of yours.
May 15, 2008 | Whirlpool MH3184XP Microwave Oven
Whirlpool microwavewave hood comination mh3184xp
My Whirlpool MH3184xps is shooting a spark when in use with the rack. When the rack is removed the oven works fine. I am guessing that some of the coating on the rack has cracked and peeled and is exposing some aluminum. Has anyone else had this problem?
Feb 04, 2008 | Whirlpool MH3184XP Microwave Oven
This is most often caused by a bad magnetron "scrambling" the controller, a bad connection on the controller, or a controller failure. Try to use the "timer" function of the oven. Make it count down without cooking for about a minute. If it works, then it's more likely to be a bad magnetron. If it still fails, it's probably a problem on the controller. We repair these nationwide by mail for $39.95 in most cases. For more information see our listing here on FixYa: http://tinyurl.com/yzjozk
Sep 22, 2007 | Whirlpool MH3184XP Microwave Oven
Microwave Ovens Logo
529 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
