Toshiba Satellite A215-S7422 Notebook Logo
Posted on Jan 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Computer doesn't boot up. tells me windows/system32/winload.exe is corrupt or damaged. what can I do?
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 86 Answers
  • Posted on Jan 18, 2010
Anonymous
Expert
Level 2:
Mentor:
Answers
86
Questions
0
Helped
12765
Points
279
Go to bios menu then give priority for cd- rom then enter f10 to save the setting after doing the setting the computer will automatically boot from the cd .if it does not bootup somtimes the problem is with your cd or cd rom
How to recover HP laptop from usb or recovery partition when winload.exe not found?
don`t loose time.
back up your files....
format and install windows from a disk!
Computer repair
Some how you have entered the bios.(either by hitting F1, F2, F12, for the delete key while in boot) simply restart your computer and everything will be fine. 3_31_2014_4_39_12_am.png
4answers
\windows\system32\winload.exe missing or corrupt 0xc000000f
":\windows\system32\winload.exe " Status: 0xc000000f This error message states a missing or corrupt Winload.exe file, due to which the booting process of the system halts and the data stored in the hard drive becomes inaccessible. Cause: Following are the causes for the corruption in Winload.exe: Software or hardware issues. Corrupt Boot Configuration Data (BCD). Incompatible partition. Resolution: To resolve the above issue, consider the measures below: To fix the corrupted Winload.exe file, use the Windows Recovery Environment. To do so, use the Startup Repair option in the System Recovery Options dialogue box and choose the operating system to repair. Using the Windows Recovery Environment will restore the system to a particular point, which will get the system to an appropriate working state. In most cases, the above measures will help you to resolve the issues related to Winload.exe. But, if the problem persists, then you will need re-install Windows. But, a clean re-install of the Windows operating system deletes all the data stored. In these situations, to recover your data completely, it isrecommended to use a high quality Windows Data Recovery Software. The Windows Data Recovery application incorporate advanced scanning algorithms to ensure quick and comprehensive recovery of your data. Stellar Phoenix Windows Data Recovery v4.1 is the most appropriate utility that recovers your lost, deleted or inaccessible data accurately. The Windows Data Recoveryapplication offers highly intuitive graphical user interface, that makes it easy to use and understand without any prior technical understanding. This recovery tool is fully competent to recover data from FAT16, FAT32, VFAT, NTFS and NTFS5 file system based disks. The read-only software is compatible with Windows 7 RCI, Vista, XP, 2003 and 2000.
1helpful
My laptop is saying i need to insert windows installation disc and restart comp file windows /system32/winload.exe status oxcoooooof info this selected entry could not be loaded because the application...
your boot record is corrupt..
get the recovery disk or install disc
then reboot and boot the install disc
the first screen has a "repair startup" option
goto there... it is all then obvious
1helpful
When i start up my computer it goes straight to boot manager and gives an error code file\ windows\ system32 \ winload exe,,, status 0XC000000F file missing or corrupt, what is the issue please, system is...
The problem you have is with the system boot files. There is a corrupt file and that is stopping the system from booting.
Press F8 as the system starts up, that will let you into the special boot menu and hopefully will give you the option of repairing your system. The timing can be quite tricky as there is only a very short time window. Trying a few times should get it.
Hope that helps.
1helpful
System32.
I'd try to insert my Windows dvd, boot from it and try to repair the installation. If thatdoesn't work, try to backup any data you want if Windows still lauches, and else you will have to reinstall Windows, I'm sorry.
I hope this helps,
Yannick.
My Computer Isn't Starting Up.
check with another Signal cable for hard disk
please attach only 1 hard disk no other drive
if same problem persist then boot from os bootable cd ,go to repair option
then run chkdsk /f utility
If still not then please reinstall your OS with repair option
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
