Question about Sirius Satellite Radio Receiver
Dual Voltage (5v / 12v) Sirius Hardwired Car Power Supply
I would like to know how to install a sirius power supply for mt Starmate 4. I have a 2004 sebring. Just need to know what wires go where. Thanks....
  • sunnyaz Feb 12, 2008
    When you say to hardwire the power supply to the vehicle's accessory circuit, where do I actually attach the wires to?. I have some fuses on the side of the dashboard on the drivers side and a fuse compartment in the engine area. Is the some sort of diagram or drawing of where to connect the wires to the accessary circuit? I am not electrical savy but can follow diagrams and instructions.
    Thanks,
    Sunnyaz
    Genius:
  • 3,587 Answers
  • 4 more comments
  • Patrick Michaels
    Patrick Michaels Feb 11, 2008
    and now more specific to that dual voltage adapter.
    Dual Voltage Power Adapter: The
    supplied Dual Voltage Power Adapter allows you to hardwire a power-source for
    your SIRIUS tuner so you don't have to use your vehicle's cigarette lighter
    port, leaving it free to charge your cell phone or other devices. The Dual
    Voltage Power Adapter is capable of supplying power to either a 12 V or 5 V
    SIRIUS portable or plug and play tuner. The adapter features the following
    connections.
    • 2-Pin Connector:
      Connection used for the supplied 5 volt cable that will be attached to your
      SIRIUS tuner
    • 3-Pin Connector:
      Connection used for the supplied 12 volt cable that will be attached to your
      SIRIUS tuner
    • Power/Ground Lead: Two 16"
      wire leads used to supply power and ground that will be attached to your
      vehicle
    Installation: The FM adaptor
    box and the Dual Voltage Power Adapter is typically mounted behind the dash,
    near the radio. In this case it's likely that no antenna extension cable or
    additional wires will be needed. Each box has 2 mounting holes to secure the
    devices to the selected vehicle's surface. The adapters are installed in the
    following manner.
    • FM Direct Adapter: Your FM
      antenna will be unplugged from your radio and plugged into the FM antenna
      port on the FM Direct Adapter. Then the adapter's 21'' motorola antenna
      cable is plugged into your radio's FM antenna port. Finally, the adapter's
      16.5" minijack cable will be plugged into the audio output connection of
      your SIRIUS tuner or SIRIUS tuner's car dock to complete the signal
      transfer.
    • Dual Voltage Power Adapter:
      Depending on your SIRIUS tuner, you will plug in either the 12 V 3-pin cable
      or the 5 V 2-pin cable into the adapter and into your tuner's dock DC input.
      The ground wire will then be grounded to the vehicle's chassis using the
      supplied ring terminal that is already installed on the ground wire.
      Finally, the power wire will need to be hardwired to your vehicle's
      accessory circuit. A 2-amp fuse and fuse holder is supplied to go in between
      the adapter's power wire and your vehicle's accessory wire.
  • Patrick Michaels
    hope that gets you there. Can't interpret the Sebring accessories connection, but it's most likely accessible through the fuse panel, no?
  • Patrick Michaels
    Patrick Michaels Feb 12, 2008
    so, is this a lock. Can you fixya my solution?
  • Patrick Michaels
    the fuse panel will show a fuse with ACC on it, usually around 15 or 20 amp fuse. There are usually some connectors(like a metal tab) on one end of those. I went online to find a wiring diagram, but nothing came through. I'll bet you might be able to go to a local auto parts store, and ask to see the fuse panel diagrams, without having to order the book. The Sirius folks only refer you back to your vehicle information. The red and black wires are simply as follows:
    Black goes to any ground wire installation on your panel.
    Red goes to the 'downstream' side of the fuse(farthest from the battery side).
    Hope this gets you closer to this.
    Patrick
    Are we closer to a Fixya?
  • Patrick Michaels
    From another source. Check this against your fuse panel, up under the console, before messing with anything. Note the Accessory locations.
    12volts pink/black (40A), red (20A) + ignition harness
    Starter yellow + ignition harness
    Second Starter N/A
    Ignition dk. blue + ignition harness
    Second Ignition dk. green/red (20 AWG) + ignition harness
    Third Ignition N/A
    Accessory black/orange + ignition harness
    Second Accessory black/white or black/lt. blue + ignition harness
    Keysense lt. blue - ign. harness or BCM, conn. 1, pin 4
    Notes: The BCM (Body Control Module) is attached to the fuse/relay
    box at the end of the dash on the driver side. Connector 1 is a 16 pin
    plug on the side of the BCM facing the front of the vehicle.
    Power Lock white/dk. green + BCM, conn. 4, pin 15
    Notes: Lock is positive trigger thru a 2.7K ohm resistor. Unlock is positive trigger thru a 620 ohm resistor. MUST use relays.
  • Patrick Michaels
    I am grateful for this opportunity to help you out.
Radio shows antenna not deteted or acquiring signal but does not work . antenna and all connections are good, ??
The problem is likely the actual connection inside the Starmate. It sounds like you have tried alternate antennas, which can only mean the unit itself has an issue. What has likely happened is the antenna jack inside the radio has come loose and is no longer making a connection, in which case it could be repairable. Otherwise there are plenty of other 12v Sirius receivers compatible with the same connections if you are looking to replace the head unit.
Jun 08, 2011 | Sirius Satellite Radio Sirius Starmate ST1...
Just bought a car and it had hardwired sirius radio already installed. I called and activated it with Sirius radio and tried to get assistance from them on how to get it to work. They gave me instruction...
The "hard wired" version that you speak of apparently only refers to the power supply.Do you have a seperate display for the Sirius unit? Now, you failed to mention the type of radio (factory or aftermarket); so, if you have to use an "empty radio station" then you have an FM modulator. This modulator could wired or wireless. The wired version interrupts the vehicle antenna wire and the station on said modulator is usually preset to either 88.1, 88.3,88.7, or 89.1. There is no need to power this modulator up, it comes on when then Sirius comes on. One way to check for power is to turn on the Sirius unit and tune your radio to an occupied Fm station. Wait a few seconds and listen to the reception. Turn off the Sirius unit, the reception should improve for the occupied station. If it is a wireless FM modulator it also has preset stations that you can change but, extending the wieless antenna will greatly improve your reception of the Sirius stations.
Sep 17, 2010 | Sirius Car Audio & Video
Sirius starmate 2replay has no sound. how do I go
When you hit the menu button go to FM transmitter and make sure is is turned on, and sellect a frequency
to set it to that is not being used by a radio station, tune you radio to the same frequency. if you are using the audio out on the starmate to plug directly into an aux in on you stereo, there should be a audio level adjustment in the menu as well.
Aug 17, 2009 | Rio SIRIUS Starmate Replay Receiver
Starmate boom box has no audio
Go into the menu and make sure the audio out is turned up
Jul 05, 2009 | Rio SIRIUS Starmate Replay Receiver
Sirius Starmate Power
My Sirius ST1 receiver froze. It reads "Sirius Radio" with the logs but goes no further in booting up. Any solutions?
Nov 12, 2008 | Clarion SIR-CL1 SIRIUS Radio Receiver
I have the same problem. It happens even more with a generic universal power cord instead of the Sirius brand one.
Apr 16, 2008 | Sirius Starmate ST2 Satellite Radio...
Sirius Starmate 4 - locks on the "Sirius: screen
with starmate 3 press at same time menu +memo+band with the radio on (with sirius screen only)
Aug 21, 2007 | Rio SIRIUS Starmate Replay Receiver
"buzz" when Sirius receiver is plugged into AUX input of new Camry
Did you have the unit installed at a shop that would have hardwired the power source? It sounds like either your power wire to the sirius unit is connected to a noisy power source (which is why you are picking up the alternator whine), or you have a poor ground connection to the unit. If it was installed at a shop, take it back and have them move the power source to the same wires that the radio gets power from. If you are using your cigarette lighter for power, unfortunately it sounds like your outlet doesn't give you the best source for powering an audio component. You might try stopping by a car audio shop and ask how much it would cost to hardwire the sirius' power to the back of your radio.
Nov 07, 2006 | Sirius Satellite Radio Sirius Starbase...
Sirius Satellite Radio Receiver Logo
350 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
