Question about Hoover Self-Propelled WindTunnel Bagless Upright VacuumVacuum
Hoover windtunnel Self-propelled - brush roll stops
There isn't enough tension on the brush roll. Not sure if it is the spring, brush roll, or wheel. Has anyone had this problem and what was the fix? Not sure which to replace first. Thanks
  • 2 more comments
  • Rbrucec Feb 11, 2008
    By the way, this is the bagged model, U6445-902. Also the outside of the belt where the wheel touches has no wear, i.e. there is no fading on the numbers, and it is the correct part number for the model, 38528034. Thanks.
  • Rbrucec Feb 12, 2008
    Thanks for the advice, I will replace the belt and see if that resolves the problem.
  • dkay_10 Dec 21, 2008
    The brush roll is not working when the arm is down. On top of vacuum where it says brush roll red is always in off position. Just replaced the v belt and drive belt.
  • Anonymous Mar 15, 2014
    brush will not roll on hoover mach 5
    President:
  • 1,673 Answers
There is a idler wheel that will drive the V belt, sometimes they jam and you just have to reach in, push and make sure if comes in contact with the belt. Alot of times tho it is the other flat belt, 38528035 that will stretch and can cause you to have problems with the brush roll not turning.
Posted on Feb 12, 2008
Brush won't spin on hoover wind tunnel bag less upright when on carpet, belts are fine
The belts may look fine but may be stretched and worn. Replace them. Make sure brush spins free. Idler pulley should tighten belt tension when handle is released
Jul 25, 2014 | Hoover U6630-900 WindTunnel Bagless...
My hoover windtunnel upright self-propelled..seems the rollers are turned off. where is switch to turn them on?
The switch to turn the brush roll on and off is on the top cover of the nozzle housing
Jul 22, 2014 | Hoover Vacuums
U6485-900 WindTunnel Self-Propelled I changed the belts but there is not enough tension on the brush drive belt to get it to rotate
I had the exact same problem with my Hoover U6485-900 Anniversary upright, self propelled, vacuum. It would move backwards and forwards, had good vacuum, but wouldn't pick up much because the brush/roller was not turning very well. I replaced the main drive belt (38528035) and it now works great. The old belt had stretched and was slipping under load. Thanks for the great suggestions.
Aug 02, 2013 | Hoover U6485900 Bagged Upright Vacuum
Brush roller on Hoover upright stops turning
There should be a belt tensioner for the V belt, maybe it is not contacting the belt when you tilt the handle back. If this is less then 1 year old, then it is under warranty, take it in to a warranty servicer for warranty repair.
Dec 13, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuum is not self-propelling and no suction
Replace your rubber belt, it is what powers the self-propel mechanism.
Remove the 4 screws from the baseplate and replace the belt at the rear of the machine.
-R
Sep 29, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U6634-900 self propelled, brush belt keeps coming off.
unfourtunatly it could be the height of your carpet also using on area rugs could cause it to do that too. check the brush roll and make sure it is spinning freely.
Aug 29, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Brush Roll belt won't engage on WindTunnel self-propelled
When you had the brush roll off, did the ends turn freely? If not then the brush won't turn and the belt will just slip. You would have to replace the brush roll if either of the ends are frozen. Other then that you would have to remove the top cover to see if there any broken parts, there is a spring loaded asm, it has a black wheel that will push the V belt when it is in the carpet setting and the handle is in the down position, it could be jammed so the roller is stuck.
Jul 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover wind tunnel upright self propelled. U6473-900. Brush does not work. Heard it was a 'brush controller' problem and can be fixed. Please tell me how.
Most likely the flat belt has stretched enough so as to not turn the pulley that in turn turns the brush roll using a V belt. Also there is a small idler wheel, if hook up, then it won't engage the V belt.
May 20, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover wind tunnel vac
If the belt is getting hot, then it is slipping instead of turning the brush roll. Check thge brush roll, make sure the ends are turning freely. Is the motor running ok? If it is then either the brush roll is bad, need a new belt, or something is catching the belt, not letting it move.
Mar 22, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Self-Propelled WindTunnel Bagless Upright VacuumVacuum Logo
1,080 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
